Page 2 of 3 1 2 3
Re: T-Case ... need options... [Re: trav] #822741 07/11/07 06:26 AM
94rodeo Offline
I don't know of a write up as of yet, but rob's site does have a lot of good pics and some of my pics are on my webshots account. I guess I could try to keep good notes and pics of the one I am doing right now and make a write up.
Troy
Re: T-Case ... need options... [Re: trav] #822742 07/11/07 02:58 PM
L
Locomigo Offline
Trav...
Have an auto 'zu case sitting in my garage. It's Steve's (the mayor) as it came with his tranny he got from the recycler. I would imagine he would make you a great deal on it...
If not, when I get the tranny replaced in mine, it also has a tcase attached.
Re: T-Case ... need options... [Re: Locomigo] #822743 07/12/07 05:22 AM
trav Offline OP
Web address for that website??
Humm... maybe i'll be interested in that t-case ya got there big guy... he he he....
1998 Isuzu Rodeo -- slightly modified.
Re: T-Case ... need options... [Re: trav] #822744 07/13/07 03:21 AM
RobG Offline
Re: T-Case ... need options... [Re: RobG] #822745 07/14/07 12:40 AM
94rodeo Offline
Mine should be in my signature.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: T-Case ... need options... [Re: 94rodeo] #822746 07/14/07 02:09 PM
4xToy Offline
link is no good. I'm also currious as to what all was done. I've seen RobG's pics but they don't explain the details. I'm thinking about trying to adapt one on the back of a np233c. I've got both the 233 and a case from an isuzu auto trans. So I figured what the heck.
-Chad
Re: T-Case ... need options... [Re: RobG] #822747 07/14/07 07:09 PM
4
4WheelDriveJoe Offline
My buddy stuck a divorced np205 behind his stock setup. <img src="/forums/images/graemlins/kewl.gif" alt="" />
seems like a lot of overkill and weight to shove behind a stock setup, you won't ever come close to needing all that strength. there are probably lighter divorced cases with better low range you could apply this same principle too.
-Rob
This from a guy who put a 14 bolt in his rodeo <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
97 Rodeo
Re: T-Case ... need options... [Re: 4xToy] #822748 07/14/07 09:00 PM
strawmyers Offline
Isuzu Moderator
link is no good.
Here you go, just needed cleaned up a bit:
Sean Strawmyer
Re: T-Case ... need options... [Re: strawmyers] #822749 07/15/07 01:33 PM
4xToy Offline
Thanks. Are those 2 mua5 cases? I'm gonna try and use an auto case out back behind my 233. What are those side gears to? did you reuse them? I haven't been into the isuzu case yet but the 233 is pretty simple. I can cut the front output side off pretty close but it is a drivers side drop so " should have plenty of room. I already see an advantage to the auto case cause it is cable shifted.
-Chad
Re: T-Case ... need options... [Re: 4WheelDriveJoe] #822750 07/15/07 03:35 PM
RobG Offline
ha! <img src="/forums/images/graemlins/lol.gif" alt="" /> but I do have a 302/C6/203/205 combo sitting in my garage that will some day find its way in front of that 14bff.
-Rob
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6419 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-07-09 20:47:26 UTC
