rear end Qs
#823184
07/05/07 03:32 AM
ok i have a 91 pickup manual tranny 4cyl i blew the carrier up so i was wondering if a rear end from a 93 manual truck with a v6 is the same gear ratio as my 4cyl truck cause i can get it for $100
i love playing in the mud
Re: rear end Qs
[Re: Bigbadtoy]
#823185
07/05/07 04:26 AM
it will bolt right in if it has 4.10's. i think some v6's came with 4.56's though. oh, and you'll have to change the flange on the pinion for your 4cyl driveline
87' ext cab toy
Re: rear end Qs
[Re: lethe]
#823186
07/05/07 03:36 PM
Toyota Moderator
As mentioned, you will need to check the ratios to make sure they match.
The flange will not need to be changed though. The bolt patterns are the same.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5920 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-06-07 02:16:28 UTCValid HTML 5 and Valid CSS
