OME bushing grease? #823193 07/05/07 02:59 PM
btn Offline OP
OME states that only lithium molybdenum disulphide grease can be used on their poly bushings. Does anyone know why? What would happen if one used synthetic grease or Anti-Seize?
Thanks.
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: OME bushing grease? [Re: btn] #823194 07/06/07 12:18 AM
Vanishing_Point Offline
I very much doubt a whole would happen. No grease would be worse.
Re: OME bushing grease? [Re: Vanishing_Point] #823195 07/06/07 01:11 AM
canuck Offline
For the extra few bucks I use moly grease front to back on the u-joint and front end. I think its got to do with heat and melting point of the grease, any how in Canada it costs me about $2 more fore a grease job all the way around using a far superior grease. Even use it in my front hubs and anywhere else you need grease. Don't be a cheap skate with this one.
Keep the Shiney Side up. Support our troops.
Re: OME bushing grease? [Re: btn] #823196 07/06/07 01:16 AM
canuck Offline
Didn't read your post all the way. DO NOT USE ANTI SEIZE ON BEARING ETC. Anti seize is for bolts etc not to seize not for high speed bearings etc. I have heard of people using anti seize for building engines etc. Anti seize has metal particals in it (usually copper). Anti seize for bearings <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: OME bushing grease? [Re: canuck] #823197 07/06/07 04:13 AM
W
Whizkidder Offline
x2 on high speed bearings, but I believe he's talking about suspension bushings -- I've used anti-seize on anti-sway bar bushings for years -- the only consistently reliable way to keep them from squeaking. Regular grease seems to squeeze/wash out much sooner. Anti-seize seems to lubricate them just fine, and lasts almost forever.
Re: OME bushing grease? [Re: Whizkidder] #823198 07/06/07 04:39 AM
4Crawler Offline
Most anything works fine on polyurethane bushings. I usually run a graphite loaded wheel bearing grease as I find that over time the graphite tends to stay in the bushing and help keep down the squeaks.
Re: OME bushing grease? [Re: 4Crawler] #823199 07/06/07 05:26 AM
Yeah, I wasn't referring to bearings! <img src="/forums/images/graemlins/scared.gif" alt="" /> Rubber and Poly bushings!
Re: OME bushing grease? [Re: Vanishing_Point] #823200 07/06/07 03:58 PM
4Crawler Offline
On rubber bushings, you only want to use something like silicone grease. Most petroleum-based greases will soften and damage the rubber bushing material.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6225 MB (Peak: 0.7207 MB) Data Comp: Off Server Time: 2026-07-14 09:35:32 UTC
