4JG2 conversion into a '91 trooper #823373 07/05/07 09:58 PM
P
PLammer Offline OP
Hello all. I've been looking for a 4JB1 for a few months now and not having any luck (I'm using the same importer Adrian used, but supply seems to have faded). So now I'm curious about using a 4JG2 instead of the 4JB1. My understanding is that the '92-'95 4JG2's are mechanical injection which is what I'm looking for. Does anyone know if the 4JG2 uses the same motor mount points for the motor/transmission? If the same mount points are used (if it's a bolt in motor/transmission mount affair) like the 4JB1, then I'll go for that motor (I guess there are a few available through the importer).
Thanks in advance!
Paul
Re: 4JG2 conversion into a '91 trooper [Re: PLammer] #823374 07/06/07 02:54 AM
JLEMOND Offline
THE MOUNTS SHOULD BE IN THE SAME LOCATION, BOTH ENGS WERE USED AT ONE TIME OR THE OTHER IN THE SAME VEH AND THE ENG IS IN THE SAME FAMILY OF ENGS , FROM THE DRAWING THAT I HAVE THE FOOT PRINT ON BOTH ENGS LOOK TO BE THE SAME
ONE IS JUST A LARGER DISPLACEMENT ,JERRY
Re: 4JG2 conversion into a '91 trooper [Re: JLEMOND] #823375 07/06/07 02:32 PM
P
PLammer Offline OP
Thanks so much Jerry. I'll be talking to the importer again next week, I'll see if he has access to a mechanical inj. G2 that he can get me, or if he can source one.
I appreciate your help.
Paul
Re: 4JG2 conversion into a '91 trooper [Re: PLammer] #823376 07/06/07 04:00 PM
A
acy76 Offline
What Jerry has said above echoes what I've read in various places - I have even heard that the two engines share the same block casting. My guess is that the 4JG2 would drop right in.
This is, however, all anecdotal evidence, unfortunately -- now you'll get to pioneer a diesel conversion, too, Paul! (Although I really think the process will be basically identical to what I've done with the 4JB1).
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6014 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-05-29 18:49:21 UTC
