'86 running rich
#823386
07/06/07 02:48 AM
Tail pipe is black. Choke isnt the issue. Any adjustments on these carbs I can make? Any suggestions??
Re: '86 running rich
[Re: opusthe2nd]
#823387
07/06/07 05:16 AM
I just bought an 84 4Runner that is also running rich, so today i started digging into it to figure out what was wrong, and i found that the aux accelerator pump (AAP) is leaking fuel into the vacuum lines, so time for a rebuild. check for this problem on your truck.
[Re: myyota]
#823388
07/06/07 06:13 PM
Wow! Too many wires and vacuum hoses on this thing, way over my head. Time to find a carb with 1 vacuum hose on it, and no wires.
[Re: opusthe2nd]
#823389
07/07/07 04:39 AM
scerbs carb facts will fix you right up .the only vac you absolutly have to have goes to the distributor.these carbs arent too bad if you take your time .I used to waste a lot of fuel running rich ,my oil smelled like gas too.
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
[Re: cktoy]
#823390
07/07/07 06:29 AM
[Re: opusthe2nd]
#823391
07/07/07 01:11 PM
Carb FAQ <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Dave 86 4Runner, 22R-EB
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6074 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-07-15 13:40:28 UTCValid HTML 5 and Valid CSS
