parking brake adjustments??? #823519 07/06/07 10:41 PM
toyotateen88 Offline OP
i need to adjust my parking brake on my 88 4runner.. does anyone have a link for me to go to. for a diagram
shane,88 toyota 4runner, v6, 5spd, 31x10.5x15 pro comp mudders, pacer wheels, flowmaster exaust, cold air intake.
Re: parking brake adjustments??? [Re: toyotateen88] #823520 07/06/07 11:33 PM
4Crawler Offline
Turn the adjuster nuts on the center section, one of the nuts visible in the photo below:
Set for ~10-14 clicks on the handle as I recall, or see the FSM link at the top of the forum.
Re: parking brake adjustments??? [Re: 4Crawler] #823521 07/07/07 12:00 AM
toyrunner Offline
Before you adjust the parking brake, adjust your rear brakes and then take up the slack.
That in of itself will help the rear brakes and the parking brake perform better.
danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: parking brake adjustments??? [Re: toyrunner] #823522 07/07/07 03:46 PM
well the problem i have is its dragging.i think it has something to do with the helper springs i put in. to lift the rear back up even with the front.
Re: parking brake adjustments??? [Re: toyotateen88] #823523 07/07/07 03:53 PM
4Crawler Offline
Are the e-brake cables hitting the springs?
If so, you might need something like this:
http://www.4crawler.com/4x4/ForSale/Shims.shtml#ToyotaEbrakeExtensions
Re: parking brake adjustments??? [Re: 4Crawler] #823524 07/07/07 04:08 PM
they are like barely touching they have about an eigth of an inch clearance.
Re: parking brake adjustments??? [Re: toyotateen88] #823525 07/07/07 04:31 PM
trickster Offline
Another common problem with the rear e brake is the pivot point of the arm on the backing plate. Tends to freeze up and not release. Crawl under there and try to move it through its range of motion, particularly to see if it moves back to a released position. I have to lube mine at least once a year.
Re: parking brake adjustments??? [Re: trickster] #823526 07/07/07 08:15 PM
rlelvis Offline
FWIW I just went through a nightmare with my e brake, this is how I fixed it.
First backed of the cable adjustment as much as possible as shown in the pic
Second adjusted the brakes to tollerance as shown in the FSM
Third adjusted the parking break lever at the backing plate, about .010 clearnce to the stop and reinstalled the spring
Last adjusted the cable, I went with 14 clicks
and made sure all moving parts were free and well lubed including the brake shoe contact points, again as outlined in the FSM.
Hope this helps. BTW my cable is original and has yet to stretch to the point of being unusable. This was my first real experience with the rear or parking breaks but if adjusted in this way I am sure it will work.
1985 4Runner, 250K, Stock, project for sure.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6240 MB (Peak: 0.7222 MB) Data Comp: Off Server Time: 2026-06-07 03:43:42 UTC
