bent relay rod? #823606 07/07/07 04:18 AM
fishy97t100 Offline OP
My steering wheel is at 2 o'clock right now when driving straight...after I ran over a fair size rock pretty hard unintentionally (driver side). Ok, so I need an alignment but maybe bent something. It seems like the tie rod is hitting the ...crossmember tower? -not sure what its called. What did I bent? With the wheels pointed straight, there is about 1/4" clearance between the tie rod and the crossmember tower on the driver side. On the passenger side, there is about 1/2"
with wheels straight:
wheels turned left:
wheels turned right:
1997 T100 SR5 xxcab 4WD 5spd D44, AAM 11.5, dual case
Re: bent relay rod? [Re: fishy97t100] #823607 07/07/07 06:03 AM
ErikB Offline
Toyota Moderator
Center link looks bent to me and looks like its causing the TRE to rub on the frame. I would check your idler arm too since that is usually the weakest link.
The center link should be straighter than yours looks.
http://home.4x4wire.com/erik
Re: bent relay rod? [Re: ErikB] #823608 07/07/07 01:51 PM
Jake97T Offline
2nd on the pitman arm, looks bent at rod end side as well as the pivoting end at steering box...
steering relay rod also bent,
ive hit some rocks i was sure did that to my front end...scary . <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: bent relay rod? [Re: Jake97T] #823609 07/10/07 08:35 AM
adam Offline
In the 1st pic it does look like the pitman got straightened out a bit, but in the other two it looks okay to me. That centerlink is wasted, though. Nice job!
~Adam
Re: bent relay rod? [Re: adam] #823610 08/22/07 03:02 PM
I finally got it fixed. I took it to the dealer and they fixed it for free <img src="/forums/images/graemlins/smile.gif" alt="" /> What a difference...I just realized how bad it was. Yup, the centerlink was wasted. .....recall
Re: bent relay rod? [Re: fishy97t100] #823611 08/22/07 05:11 PM
kustomyoung Offline
You're lucky, that's the weak end of the relay rod - when they pop it's almost always at the taper where the pitman arm mount is. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1995 Toyota SR5 T100 4x4
2003 Toyota SR5 Tundra 4x4 *SOLD*
1968 Ford Bronco
loud squeal [Re: fishy97t100] #823612 01/28/08 09:25 PM
So i now have a loud squealing noise when turning (stationary position). Before, it would only make that noise at full turn. So im thinking of replacing the bushings on the idler arm and....rebuild kit for the steering box? Sluggish steering at 0-low speeds or when it is under stressed (i.e. aired down tires, downhill/uphill). PS fluid level is ok.
Anyone selling a used TC idler arm?
Re: loud squeal [Re: fishy97t100] #823613 02/19/08 06:57 AM
turns out to be...its the power steering belt slipping. i just re-tension it. still does it though at full turn. ive always thought its the steering stop.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6240 MB (Peak: 0.7234 MB) Data Comp: Off Server Time: 2026-10-30 10:20:21 UTC
