Need TIming Chain Help Quick! #823699 07/07/07 06:34 PM
SALMONHEAD Offline OP
Well I'm 1/2 way into my first TC replacement on my early 22r & need help. The harmonic balancer had been sleeved before and was grooved again. The new sleeve from engnbldr is not as deep by about 3/16" as the one that was in there before. The old one seated all the way to the back of the HB snout and had a lip. I put the new one on flush but when I put the HB back on I can't see if the sleeve is covering the seal surface or not. If this going to work or do I need to try and find a different sleeve. I'll be waiting under the Truck!
Thanks to anybody.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: Need TIming Chain Help Quick! [Re: SALMONHEAD] #823700 07/07/07 08:57 PM
MAC Offline
If it's EBs stuff I would think it should be good to go. Never heard of anyone having a problem with that when using his stuff. But, if I was uncomfortable, I would pull off the HB and measure from the cover face to the seal lip, then measure the HB sleeve length and maybe mark the sleeve with a marker and figure where you are.
Re: Need TIming Chain Help Quick! [Re: SALMONHEAD] #823701 07/07/07 08:59 PM
4crawler or engnbldr out there? My harmonic balancer has 3 pulleys if that makes any difference. One parts place said they had a listing for a "long speedi-sleve" but he didn't have it.
Help anybody?
Thanks
Re: Need TIming Chain Help Quick! [Re: SALMONHEAD] #823702 07/07/07 11:09 PM
MAC Offline
seal area is the same for 2 or 3 pulley.
Re: Need TIming Chain Help Quick! [Re: MAC] #823703 07/08/07 12:52 AM
CJM Offline
yes .. as long as the sleve is covering the "groove" from the old seal on the HB .. you'll be good to go ..
just make sure you lube the seal lip , and the speedy sleeve , otherwise you could "tear" it on start up .
83 Trekker SR5
NEW Trekker forum
Re: Need TIming Chain Help Quick! [Re: SALMONHEAD] #823704 07/08/07 01:05 AM
Thanks to all! I'll finish putting it back together.
I appreciate the response!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6074 MB (Peak: 0.6772 MB) Data Comp: Off Server Time: 2026-07-09 21:39:58 UTC
