02 sensor problem, need help #823729 07/07/07 09:43 PM
P
palo Offline OP
I have a 2004 jeep Liberty Limited 4x4 with a 3.7L engine, The engine light came on and is throwing a code PO138 which is telling me there is a problem with one of the o2 sensors. It's telling me bank 1 sensor 2. Can anyone tell me which one of the o2 sensors is considered to be bank 1 sensor 2?. I can only see two sensors on the system, one on the right side front pipe closest to the r/s manifold and the other on the rear of the cat. Thanks for all responses.
Re: 02 sensor problem, need help [Re: palo] #823730 07/07/07 10:15 PM
BigJim Offline
That being a V type engine I'd guess there is a sensor on BOTH sides of the engine. Bank ONE should be the bank with the #1 cylinder on it...OR the most FORWARD of the front cylinders. I think you have missed locating one or more of the sensors.
Re: 02 sensor problem, need help [Re: BigJim] #823731 07/09/07 07:53 PM
P
palo Offline OP
Thanks BIGJIM,I will look at the exhaust and see exactly how many sensors are there. I was wondering thou if bank 1 is the side of the #1 cylinder which o2 sensor would be sensor 2 on the code readout?. Thanks again for all your help, very much appreciated.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5916 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-07-17 02:19:03 UTC
