3L V6 low RPM miss ? #823915 07/09/07 05:23 AM
6
6Gun Offline OP
1992 4Runner, V6, 5 speed, 170K. It Starts and accelerates easy, but at 25 to 35 MPH it does not run smoothly. It jerks badly, if I step on the gas it will accelerate smoothly right on up. It is just when IÆm trying to maintain an even speed around 1500 to 2000 rpm. IÆve checked for obvious vacuum leaks and can find none. Any and all ideas will be appreciated. Thanks, PeterY
Re: 3L V6 low RPM miss ? [Re: 6Gun] #823916 07/09/07 08:05 PM
DRTDEVL Offline
Run a compression test... Wet and Dry.
Sounds like you toasted the exhaust valves on 1 or 2 cyls (prob #5 or #6). Very common issue around your mileage.
Re: 3L V6 low RPM miss ? [Re: DRTDEVL] #823917 07/09/07 11:25 PM
6
6Gun Offline OP
I will check them but let me ask would there not be other problems caused by a bunch of burnt exhaust valves? There is plenty of low RPM power. The problem is noticed around 1500RPM. Any other ideas cause it appears to be a very well taken care of truck or I would not have bought it. I would add a couple pics if I could figure out how... thanks, Peter
Re: 3L V6 low RPM miss ? [Re: 6Gun] #823918 07/10/07 05:50 AM
canadiantoy2 Offline
My miss wat at 1200 RPM and it was caused by a bad TPS.
CT
Re: 3L V6 low RPM miss ? [Re: canadiantoy2] #823919 07/11/07 02:51 AM
6
6Gun Offline OP
Did the bad TPS set off your check engine light? I would think that it should. If I can I will unplug the wires to it and see what happens, as soon as I can find it... Thanks.
Re: 3L V6 low RPM miss ? [Re: 6Gun] #823920 07/13/07 04:05 AM
kewlynx Offline
We've got a 93 FSM sticky'd in the early trucks section that'll be helpful to you. It contains both 22RE and 3.0 info, so mind what you read. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6090 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-23 22:45:39 UTC
