High Pitch Squeal at high RPMs??? #823959 07/09/07 01:31 PM
A
ADAMan Offline OP
I have a 1993 4wd 22re, runs good and solid. It started making a high pitch squeal at high RPMs. I have new belts, and I recently sprayed belt dressing on them to try to alleviate the problem, no luck though. I have not steam cleaned the engine, due to its age and the fear of doing some type of damage, (thinking dust may be the culprit). Is this a "warning" that something may be about to go out, bearing?, pulley? timing chain? I dont have a tach, so by high RPMs I mean 30-35 mph in 2nd gear, it squeals just before the shift into 3rd. This morning it squealed at 42 just before the shift into 4th..Thanks for any info.
Re: High Pitch Squeal at high RPMs??? [Re: ADAMan] #823960 07/09/07 04:03 PM
DRTDEVL Offline
Steam clean it anyway...
Check the water pump weep hole for leakage.
Re: High Pitch Squeal at high RPMs??? [Re: DRTDEVL] #823961 07/10/07 04:43 AM
CJM Offline
power steering ???
might be the idler pully bearing ..
83 Trekker SR5
NEW Trekker forum
Re: High Pitch Squeal at high RPMs??? [Re: CJM] #823962 07/10/07 01:30 PM
A
ADAMan Offline OP
Yes I have power steering. If I do have an idler pully bearing go out, what should I replace during the breakdown?? I would be having it done, as I do not have the knowledge to do it myself. My truck has 196k on it. Timing chain?
Re: High Pitch Squeal at high RPMs??? [Re: ADAMan] #823963 07/10/07 02:06 PM
ACES_HI Offline
Chances are that your belts still slipping. I've been down the same road and belt dressing didnt work. Retighten the belts. If that doesnt work then chances its a bad idler pulley bearing. Heres a link to an old thread about the pulley. link
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: High Pitch Squeal at high RPMs??? [Re: ACES_HI] #823964 07/11/07 05:17 PM
Y
yotaman1224 Offline
are you running the ac on as you are doing this, my ac compressor makes this horrible noise at high rpm only when ac is on though
Re: High Pitch Squeal at high RPMs??? [Re: yotaman1224] #823965 08/27/07 08:16 PM
A
ADAMan Offline OP
A little more info on this. It starts at startup when it is really hot outside, when I leave work in the afternoon. It lasts until I put it in first gear and stsrt to drive. The Clutch depressed or not does nothing. Revving it up a tad does nothing. It will not squeal when I crank it in the morning to go to work. The AC on or off has nothing to do with it. Any Ideas, advice??.......Thanks
Re: High Pitch Squeal at high RPMs??? [Re: ADAMan] #823966 08/29/07 12:23 AM
G
GOI87 Offline
Is your engine oil toped off? May sound Stupid but it's well worth it to check. While your at it, you might check all of the fluids.
Maybe spray some WD-40 on the pullies to see if it goes away. The WD-40 will only make it go away for a short time, but if it does go away at all, then you'll have a clue where your problem is.
Does it matter if the truck is cold, warm, warmer, or hot?
Good luck,
GOI
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: High Pitch Squeal at high RPMs??? [Re: ADAMan] #823967 08/29/07 12:22 PM
ACES_HI Offline
Unhook your belts one at a time and run the engine. When the squeal stops you found the bad belt or idler pulley. Check the pulley and either repack the bearing or replace it and TIGHTEN the belt tightly. I had the exact problem and turned out I wasnt getting the belt tight enough.
Re: High Pitch Squeal at high RPMs??? [Re: ADAMan] #823968 08/29/07 04:09 PM
ZUK Offline
I had the same thing happen on my 92 22RE....dam alt belt. Belt spray might help....tightening it may or may not help. Some belt brands just do not "fit" well on the pulley and will loose grip.
mostly stock
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.017s) Memory: 0.6387 MB (Peak: 0.7620 MB) Data Comp: Off Server Time: 2026-07-16 03:24:40 UTC
