Any tricks for getting the upper ball joint back together?
#824143
07/10/07 03:21 PM
Getting the upper and lower ball joints apart was loads of fun. I've got the lower ball joint back together by letting the vehicles weight onto it. The upper doesn't work that way unfortunately.
So without any weight on it the ball joint bolt spins with the nut as I try to screw it back on. I would hit it with the air tools but there isn't even enough room for a wratchet and socket in there because the ABS sensor line gets in the way.
Anyone have any tricks for me?
Thanks, --jeremy
Re: Any tricks for getting the upper ball joint back together?
[Re: HCMP]
#824144
07/10/07 03:40 PM
What worked for me is to put a C-clamp, one end on the end of the threaded shaft, but at an angle, and the other end on the knuckle. Tighten it as best you can...the goal is to sorta jam the shaft in place so you can tighten the nut. Hope that make sense...
Steve Carlson - 95 Trooper LS expo rig Serenity now!
[Re: BigSwede]
#824145
07/10/07 05:52 PM
That sounds like it could work. I was eyeing up my ratchet strap (finally figured out that there is no "W" in ratchet) last night wondering if I could wrap (there is a "W" in wrap) it around both control arms to force the top arm down.
Maybe with their clamping and ratcheting forces combined....
[Re: HCMP]
#824146
07/11/07 12:27 AM
What worked for me is to put a jack under the lca and try to get as much weight on it as possible. Then use quick short jerks (kinda like trying to break a nut loose but in tightening mode). That allowed the nut to tighten a little at a time till it was tight enough to grip.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO on US Wheel 94 series 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
[Re: Gizzy42]
#824147
07/11/07 06:29 AM
I just chopped the whole set up out <img src="/forums/images/graemlins/evil.gif" alt="" /> What I did with my Ifs was hit it with a hammer at the same time I would give a good jerk on the ratchet.
Troy
94 Rodeo sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url] http://community.webshots.com/user/94rodeo[/url]
[Re: 94rodeo]
#824148
07/16/07 01:33 AM
The C-clamp method worked perfectly, Steve. Thank you
--jeremy
[Re: HCMP]
#824149
07/16/07 01:15 PM
No prob, I learnt that technique from Mike Walter (muskyamigo)...
