302 YJ swap #824184 07/10/07 08:02 PM
X
x89yjx Offline OP
i recently picked up a ford 302 and C6 tranny from a friend for free. my 258 is getting tired and now would be a great time for a swap. the motor already has a rear sump. my issue is with transmissions. my jeep is an 89 YJ with an AMC 258, TF999 automatic, and np231.
-is it possible to mate the 302 to the tf999? (i understand it may not be the best match, but i can drive with a light foot until more time is available)
_could the C6 ever fit in the yj?
Re: 302 YJ swap [Re: x89yjx] #824185 07/10/07 09:08 PM
Brown81CJ5 Offline
I'm sure Advance Adapters could answer your questions. And they might even have what you are looking for.
advance adapters
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 302 YJ swap [Re: x89yjx] #824186 07/10/07 11:37 PM
BobRowe Offline
The TF999 should be fine behind the 302, if you can get them to match. Several of us around here have AMC 304 or 360 engines tied to a TF999.
Re: 302 YJ swap [Re: BobRowe] #824187 07/11/07 01:55 AM
X
x89yjx Offline OP
i shot an email to novak adapters today. i'm waiting to see what they say. that's good to hear that the tf999 should be fairly adequate. i was thinking though...automatic transmissions have the bellhousing permanently affixed...therefore a tf999 bellhousing would have to by some chance be the same bolt pattern as a ford bell housing. so if i want an automatic, i pretty much need to use a ford one right? i'm going to try to measure the C6 and TF999 to find out how far forward the motor would be pushed. a 302 should be shorter than a I6 4.2 right? my brain hurts
Re: 302 YJ swap [Re: x89yjx] #824188 07/11/07 05:33 AM
BobRowe Offline
Advanced Adapters should be able to answer those questions for you.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6060 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-06-22 06:10:46 UTC
