91 wrangler stumbling fuel? #824202 07/10/07 11:16 PM
jeepj3000 Offline OP
91 fuel injected 4 banger, 5 speed. Falls flat on it's face when I get past 1500 rpm in any gear under a load, justs acts like it's dieing, pops, let off the throttle and she's idling great but no power. Neutral revving up to 4500 rpm and it falls flat. Opened the shrader valve on the fuel rail and have a good amount of fuel at idle until it stumbles, then it falls way off. I can hear the fuel pump humming. Turn the key on and it primes up. And can also hear it while running.
Any ideas?
Re: 91 wrangler stumbling fuel? [Re: jeepj3000] #824203 07/10/07 11:25 PM
Brown81CJ5 Offline
Clogged fuel filter?
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 91 wrangler stumbling fuel? [Re: jeepj3000] #824204 07/10/07 11:30 PM
jesoe Offline
hey pal have you checked your ignition system,is your beast electronic fuel injected and electronic ignition check alternator,or have you checked fuel pressure under load to see if the pressure drops.
Re: 91 wrangler stumbling fuel? [Re: Brown81CJ5] #824205 07/11/07 01:53 AM
tried a fuel filter, was better... but won't turn over 3000rpm in 3rd or over 2400 in 4th. I have a spring over w/ 33's so I need the rpm's. Which shouldn't be an issue anyway. If you try to accelerate hard past thos rpm's it just falls flat and will backfire from time to time.
Re: 91 wrangler stumbling fuel? [Re: jeepj3000] #824206 07/11/07 03:07 AM
fishtaker Offline
How about a plugged cat/muffler? Does the exhaust make a whistling sound?
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: 91 wrangler stumbling fuel? [Re: fishtaker] #824207 07/11/07 04:20 AM
no whistling sound, new flowmaster muffler. The fuel flow out of the shrader valve is very minimal when I push it up to high rpm's. I'll try to get a guage tommorrow to put on it to see what kind of pressur I have.
Re: 91 wrangler stumbling fuel? [Re: jeepj3000] #824208 07/11/07 04:49 AM
playinmud Offline
check valve?
or is that just for starting?
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: 91 wrangler stumbling fuel? [Re: playinmud] #824209 07/11/07 01:35 PM
Brown81CJ5 Offline
Just curious as to what gears you are running with those 33's?
Gun it and run it!
Re: 91 wrangler stumbling fuel? [Re: Brown81CJ5] #824210 07/11/07 02:37 PM
bhartwell59 Offline
maybe a clogged fuel injector or one going on you.
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: 91 wrangler stumbling fuel? [Re: Brown81CJ5] #824211 07/11/07 04:51 PM
4.10
have had this jeep for a few years, problem just started a few days ago.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6317 MB (Peak: 0.7376 MB) Data Comp: Off Server Time: 2026-07-13 10:19:34 UTC
