few question #824216 07/10/07 11:24 PM
Dieselshop Offline OP
How do you pull codes on a 85? and I have a bad stumble at 2500 RPM then goes away just stumbles at 2500? the clutch is also really soft and it is a new clutch and no air in line any ideas?
sorry for all the question andy help would be great.
Rob
Re: few question [Re: Dieselshop] #824217 07/11/07 12:27 AM
4Crawler Offline
Re: few question [Re: 4Crawler] #824218 07/15/07 01:17 AM
anyone know what codes 7 and 12 are?
Re: few question [Re: Dieselshop] #824219 07/15/07 01:29 AM
rlelvis Offline
I think these apply.
http://www.4crawler.com/4x4/CheapTricks/Images/85diagnosticcodes.gif
Sounds like TPS and Knock Sensor signal.
1985 4Runner, 250K, Stock, project for sure.
Re: few question [Re: rlelvis] #824220 07/15/07 12:45 PM
thinking about it I dont think I hooked up a knock sensor, only sensor on the engine is the one by the starter. were is the knock sensor located on a early block?
Re: few question [Re: Dieselshop] #824221 07/15/07 01:35 PM
DRTDEVL Offline
Isn't the knock sensor over the oil filter?
Re: few question [Re: DRTDEVL] #824222 07/15/07 09:44 PM
i have a early carbed block, and the oil pressure sendind unit is to the left of the oil filter looking from under the tire. just below that right next to the motor mount is a plug is that were the knock sensor should go??
Re: few question [Re: Dieselshop] #824223 07/16/07 12:10 AM
4Crawler Offline
The KS is at about the 9:30 position on the oil filter in the picture below:
Re: few question [Re: 4Crawler] #824224 07/16/07 12:43 AM
strange now I am lost, the only sensor I have is the one next to the oil filter and my oil pressure guage work so I figured it was oil PSI let me take a pic that may help.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6263 MB (Peak: 0.7122 MB) Data Comp: Off Server Time: 2026-06-07 04:36:17 UTC
