Pulling Engine q #824249 07/11/07 01:47 AM
DanSweet Offline OP
Hi guys, working on pulling my 22re engine out of my truck. I believe I have everything disconnected and am trying to pull the engine out from the transmission. I can't seem to get the engine to slip out from the transmission. I can see gaps forming along the edges, but it won't seem to slip out. Is this normal for them to be this stuck together? It's never happened to me before. Thanks for any help,
Dan
94' 22re Ex Cab 4x4...pretty much stock, 2" 4 Crawler body lift and 32 x 11.50 bfg mud terrains.
Re: Pulling Engine q [Re: DanSweet] #824250 07/11/07 02:03 AM
kewlynx Offline
I take it the nut for the starter is already removed, yes?
Betcha 5 smackers that you overlooked the aft-facing bolt on the driver's side, just below the exhaust manifold. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: Pulling Engine q [Re: kewlynx] #824251 07/11/07 04:47 AM
DanSweet Offline OP
Ok, I got it. The dowel on the drivers side was just really stuck. Not like I've ever seen before. I just didn't want to break anything, but I got it. Thanks,
Dan
Re: Pulling Engine q [Re: DanSweet] #824252 07/11/07 05:22 AM
toyotaguy55 Offline
It always happens good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
Re: Pulling Engine q [Re: toyotaguy55] #824253 07/11/07 02:45 PM
Scerb Offline
I lot of times i need to wedge a prybar in there, or even gently tap on in with a hammer. Pops right apart everytime <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Scerb
Re: Pulling Engine q [Re: Scerb] #824254 07/12/07 05:01 AM
TinyTruck Offline
for future reference, grab the efi and the exhaust manifold and shake like you have a set of iron balls
1988 YOAT "Stumpy"
-Lock-Right -Fabtech spare tire carrier
-3in PA BL -Custom Flatbed
-32x11.5 cooper mall-terrains <BALD>
Re: Pulling Engine q [Re: DanSweet] #824255 07/12/07 05:33 AM
engnbldr Offline
Dan
>>>*One thing to remember when pulling any engine is to get everything into alignment. The amount of friction that can be set up by just the input shaft is amazing.
I have had literally hundreds that felt locked up tight, and a good SHAKE or lifting/lowering of the hoist and without fail they almost fall forward.
Of course there WAS one! A 292" engine in a 1956 Ford (don't ask how old I was).....
My bu**head brother and I worked on it for almost an entire day, finally let's just say he was pi**ed off. He went and got our dad's 1948 Farmall tractor, hooked up the chain and hauled the engine out.
It came, too, along with a piece of the bell housing with the bolt we missed still attached.
*LOL**...Best the shake it loose....*EB
*Beats the he** outa me!....*LOL**...
Re: Pulling Engine q [Re: DanSweet] #824256 07/12/07 02:57 PM
Cholltero Offline
Good points Ted. I've found that it never hurts to use some alignment dowles whenever possible .
Make sure you get ALL the bolts off first , then get some 2" to 6" bolts with matching threads and the heads cut off.
They'll let you know right off if your alignment is close.
Just finished reduilding a Massey diesel engine . Though it has a normal rubber seal at the torque converter / transmission, the primarary oil seal is the flange on the rear of the torque converter that mates into a babbit on the hydraulic pump on the front of the transmission---very close tolerances and metal to metal --- and if those are not perfectly aligned , you're not going to get it apart or back together without ruining something
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6233 MB (Peak: 0.7220 MB) Data Comp: Off Server Time: 2026-06-07 08:39:37 UTC
