1986 Toyota PU 4WD, need help wanting straight axle #824287 07/11/07 03:23 AM
Dez Offline OP
I want to run a dana44 in the front of my 1986 Toyota pu, i dont want ifs. Can anyone help or know anyone that has done it? Thanks
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: Dez] #824288 07/11/07 05:34 AM
toyotaguy55 Offline
Jeeze
toyotas look good with body damage
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: toyotaguy55] #824289 07/11/07 06:33 AM
OOP'S Offline
All the info you need, including getting the brakes set-up right.
http://home.4x4wire.com/erik/
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: OOP'S] #824290 07/11/07 11:01 PM
Dez Offline OP
thanks for the info
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: Dez] #824291 07/15/07 09:57 PM
Dez Offline OP
I'm getting an AllPro SAS Kit, 1049$ what axle would be best and check as well? i know its hard to find a 1985 Toy axle, if i got a Dana44 would i have to Narrow it to make it match my rear axle?
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: Dez] #824292 07/15/07 11:41 PM
OOP'S Offline
Yes!!!!!
David Fritzsche
Roseville, CA
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: Dez] #824293 07/17/07 05:57 PM
Kaptain Offline
Sticking with a Toy Front will make life alot easier... It's basically a bolt on once you have the front springs installed.
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: 1986 Toyota PU 4WD, need help wanting straight axle [Re: Dez] #824294 07/18/07 02:32 AM
fourwd1 Offline
... i know its hard to find a 1985 Toy axle, ...
The axle doesn't have to be from an 85 Toyota, any year from 79 to 85 will work, pick up or 4Runner.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 1986 Toyota PU 4WD, manual tranny problem [Re: fourwd1] #824295 07/18/07 06:26 AM
Dez Offline OP
Having a New Problem, I drove about 60 miles today and when i went to stop i pushed the clutch in and it just kept going. i thought it was the slave cylinder so i rebuilt it. And that didnt work, what else could it be?
Re: 1986 Toyota PU 4WD, manual tranny problem [Re: Dez] #824296 07/18/07 05:19 PM
fourwd1 Offline
The clutch MC or the clutch itself.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6317 MB (Peak: 0.7222 MB) Data Comp: Off Server Time: 2026-05-29 14:42:26 UTC
