2.8 hesitation #824356 07/11/07 05:00 PM
Shovel Offline OP
I've got a tired 2.8 in a 91 trooper that i've put new injectors, new plugs/wires/cap/rotor, and performance 2.5" collector-back exhaust onto... as i've done this its hesitation from standstill has seemed to get worse.
Automatic transmission, btw.
if I'm already moving, throttle response is fine - but if i come to a complete stop, then step on the gas it kinda sputters and puts out nearly no power for 1 to 2 full seconds, then BAM comes alive and accelerates like it should. Next time I come to a complete stop, the same thing occurs.
Any ideas? timing? IAC motor?
Re: 2.8 hesitation [Re: Shovel] #824357 07/11/07 08:15 PM
Ed Mc Offline
Check your T.P.S. This is easily done with a meter to see if there are any "dead spots" in the TPS's resistance curve.
If it checks out good, do the idle air/TPS Voltage checks/adjustments. If you cycle the throttle from idle to full while monitoring TPS voltage it's another good verification of TPS linearity.
I don't have the link handy at work but do a keyword search on "TPS" or "IAC" and you'll come up with good tips on doing the checks/adjustments. Or check at the www.s-series.org 60 deg V6 forum.
HTH...........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5906 MB (Peak: 0.6390 MB) Data Comp: Off Server Time: 2026-05-29 22:33:33 UTC
