Finished my SAS but ran into small problem #824388 07/11/07 11:31 PM
9
95mini Offline OP
Well I finished my SAS today <img src="/forums/images/graemlins/smile.gif" alt="" />.....kind of
Went to put the wheels on and they hit the caliper. Anyone else had this problem?
Should I buy wheel spacers or wheels to fix the problem?
95 pickup, stock ifs calipers, axle is off a pre 84 truck I think because it does not have the top gusset.
I also noticed that my calipers are a little different than the junk pick-up I tore up a couple years ago for parts....my brake pads are about 4 7/8" long, compared to 4 1/4" off the other truck. Also two of the pistons in my calipers are a little larger than the calipers that had the smaller pads. Unfortunately I only have only one of those calipers from the junk truck, gave the other to a friend.
Everything else looks great, I used toy rears up front and a marlin high steer kit.
I do have one other small problem. My passenger side sags a little, about 3/8".
I could use some suggestions on what to do and where to buy it.
I'm going to try and get some pics up tomorrow.
Re: Finished my SAS but ran into small problem [Re: 95mini] #824389 07/11/07 11:36 PM
Scerb Offline
I have v6 calipers and it does look like they would hit my rims without the wheel spacers.
Re: Finished my SAS but ran into small problem [Re: Scerb] #824390 07/11/07 11:38 PM
9
95mini Offline OP
Its a 4 cyl truck but maybe it has the v6 calipers?
What size wheel spacers do you have?
Re: Finished my SAS but ran into small problem [Re: 95mini] #824391 07/11/07 11:52 PM
4Crawler Offline
If you are running the stock wheels (~4-7/8" backspacing) you'll need ~3/4" spacers (or more) to clear the brakes/steering arms, or wheels with 4" or less backspacing.
For the sagging, a spring perch spacer will help level out the spring perch heights:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#ToyotaSpringPerchSpacer
if you are using equally arched springs.
Re: Finished my SAS but ran into small problem [Re: 95mini] #824392 07/11/07 11:58 PM
Scerb Offline
I have a 1.5" spacer, although I don't think I need THAT much to clear it. I think its just the ifs calipers in general though.
Re: Finished my SAS but ran into small problem [Re: Scerb] #824393 07/12/07 03:14 AM
Robinhood150 Offline
Yes, most people use 1.5" spacers to match the width of the rear axle.
I wouldn't worry about the 3/8" sag. Take it off road a couple times and then see where everything sits. Mine is probably sagging 1-2 inches on one side.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: Finished my SAS but ran into small problem [Re: Robinhood150] #824394 07/12/07 05:00 AM
OOP'S Offline
What type of springs are you running in the front? Some of the aftermarket springs like Pro-Comp, Downey, NWOR, and others are not equal in arch. They do that because the DS spring perch is lower then the PS perch.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6185 MB (Peak: 0.7093 MB) Data Comp: Off Server Time: 2026-07-10 02:48:02 UTC
