ok welded front diff verses lockright #824569 07/13/07 04:10 AM
cbrazor Offline OP
ok weld the diff or ad a lock right locker this is for the front diff
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: ok welded front diff verses lockright [Re: cbrazor] #824570 07/13/07 04:21 AM
BigJim Offline
If you EVER drive it on the street you will REGRET either one up there.
If you just must have a front locker you need one of the POSI ones with clutches in it so the thing will turn curves and corners on the street.
Re: ok welded front diff verses lockright [Re: BigJim] #824571 07/13/07 05:04 AM
playinmud Offline
yes sir bigjim hit the nail on the head with that one
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: ok welded front diff verses lockright [Re: cbrazor] #824572 07/13/07 05:44 AM
BobRowe Offline
You can install a Lock Right locker in the front (I have one in my CJ-7), but you will have to be in 2WD and have front hubs that are unlocked in order to drive it on the street.
Offroad, when you're on very hard dry dirt, you may have to shift from 4WD to 2WD (don't have to unlock the front hubs)when making a very sharp turn. I've only had that happen a couple of times. It's no problem for me, because I have twin-stick shifters on my Dana 300, so I can disengage the front axle easily and quickly, while leaving the rear axle in Low Range.
So, if you're into hard core wheeling, with little street use, a front auto locker isn't bad. If you use it primarily on the street, don't get one.
And I'd NEVER weld a front differential. They suck big time, even off road. Any traction at all, and you won't be able to turn it.
Re: ok welded front diff verses lockright [Re: BobRowe] #824573 07/13/07 12:51 PM
Bigbird79 Offline
The only thing I would ever put in a front is something like an ARB, so you can have it drive normal most of the time, and then when you need it on that rare ocassion, you can lock it in.
Sean
Re: ok welded front diff verses lockright [Re: Bigbird79] #824574 07/13/07 04:13 PM
superdawg Offline
I've got a customer who is having me order up his third set of D44 chromo shafts and each time I tell him get rid of that stupid front spool and even stock shafts will last.
Sorry this guy is a complete rockhead who knows best.?
SD
PS at least he does not ask for the shafts to be warrantied.
Re: ok welded front diff verses lockright [Re: Bigbird79] #824575 07/14/07 02:19 AM
fred1980 Offline
Sean
I would have to agree with this, having owned both a Lockright and an ARB upfront I would say HANDS DOWN the ARB is the way to go. It is pretty hard to make turns in 4WD with the lockright let alone tight turns offroad while in 4WD. I was always having to shift into 2WD to make a tight turn and sometimes that might not be an option offroad (I got body damage on 3 occasions from just quite not making a TIGHT ENOUGH turn when I had the front lockright <img src="/forums/images/graemlins/angry.gif" alt="" />). On the street they are pretty much the same in 2WD, but off road I like being able to easily maneuver at a flick of a switch <img src="/forums/images/graemlins/smile.gif" alt="" />
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
Re: ok welded front diff verses lockright [Re: fred1980] #824576 07/16/07 03:39 AM
cbrazor Offline OP
ok guys thanks i think il go lockright but i found something that will allow it to turn in 4 low a poi lock which is a cable replacement for the vacume on the 30 un locking it will only allow one wheel traction when i need to turn kinda like an ox locker thanks for all the input <img src="/forums/images/graemlins/patriot.gif" alt="" />my tru trac sucks it was ok for a while
Re: ok welded front diff verses lockright [Re: cbrazor] #824577 07/16/07 04:09 AM
BigJim Offline
Well that'll work...sort of anyway. By using that device with a lockright up front, the result will be that when in a righthand turn your left front will be spinning forward faster than the rear wheels...and in a lefthand turn the left front will be dragging and slipping slower than the rear wheels.. Lockers up front are a hazard on the street unless you can lockout BOTH front wheels.
Re: ok welded front diff verses lockright [Re: cbrazor] #824578 07/16/07 05:32 AM
F
Fred Blackstone Offline
Best of luck with your plans; but, I can't help but wonder why your going to so so much trouble to simply avoid dropping in an ARB locker? ARB's are not that expensive, and are the best solution to your four-wheeling needs, it seems. Their are other mechanical and electric lockers, but presently they are problematic on the trail.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6382 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-10-21 22:06:29 UTC
