swapping a '91 22re into my '84 22r carbed truck? #824813 07/14/07 05:18 AM
haulie Offline OP
My buddy recently totaled his '91 4x4 truck with a 22re engine.(nobody was killed, thank God) I'm considering buying the engine to rebuild at my lesiure and put it in my carbed '84 22r 4x4 truck.
I know I'll need to use the exhaust manifold from the '91 (for the 'pear shaped' exhaust ports), but can I bolt my carbed intake to the '91 engine? I don't want to pull the EFI wiring harness and computer from his truck and deal with all those wires, etc..., yeah, I know that fuel injection is superior, just keepin' it simple.
Also, will the '91 engine mate up with my engine mounts and running gear with out mods?
It runs good he says, I don't know how many miles are on it, I'm guessing around 100K, what do you guys think is a fair price?
Re: swapping a '91 22re into my '84 22r carbed truck? [Re: haulie] #824814 07/16/07 04:39 AM
haulie Offline OP
Anyone? I don't see why it should'nt drop in......but....., I'd hate to find out the hard way.
Re: swapping a '91 22re into my '84 22r carbed truck? [Re: haulie] #824815 07/16/07 05:58 AM
stock87 Offline
Might need to swap a couple intake mounting studs around, but everything else should be 100% bolt-on. Just keep in mind you'll need to order different parts in the future (internals) since your truck probably came with the older block.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: swapping a '91 22re into my '84 22r carbed truck? [Re: haulie] #824816 07/16/07 06:46 AM
kewlynx Offline
If you haven't already read/bookmarked this already
20R22R History
I would also be interested in obtaining the fender-mounted parts in this article off that truck if he is so inclined.
http://www.yankeetoys.org/black900rr/EFI.html
You can PM me by clicking on my screen name.
**ubi apis- ibi salus**
Re: swapping a '91 22re into my '84 22r carbed truck? [Re: kewlynx] #824817 07/17/07 07:20 AM
haulie Offline OP
20R22R History
Thanks for the link. I'm in Florida, you know....Are you gonna come down and pull the parts? <img src="/forums/images/graemlins/smile.gif" alt="" /> The beach is nice, water is warm.
Seriously though, I'll ask, I don't yet know if he is going to part it out or keep it or what.
Re: swapping a '91 22re into my '84 22r carbed truck? [Re: haulie] #824818 07/17/07 07:37 AM
kewlynx Offline
I was stationed at Eglin in the Panhandle before coming up here. I was with the Test Wing; did a LOT of time out at Holloman AFB, NM out of there.
It's warm up here without the heat index, and the fish are runnin'. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Thanks for askin' for me; just send a PM. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: swapping a '91 22re into my '84 22r carbed truck? [Re: kewlynx] #824819 07/17/07 07:02 PM
P
philly Offline
i am in the process of doing this swap.. except wiht a 94 22re into an 84 22r, u need the efi fuse, efi relay, starter relay, and circut opening relay, and cluth cancelswitch, ECU, also gas tank. and u need to know how to wire very good.. this is a hard swap i have come to find, not many people have done it. but mines almost running. i can hook u up wiht pin layouts, PM me or message me
also...most swaps u find for 22r to 22re are for 84-88engines the harness changed in 89
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6201 MB (Peak: 0.7112 MB) Data Comp: Off Server Time: 2026-06-20 17:52:25 UTC
