Re: Cheap easy tricks for the stock toyota IFS [Re: JackKnife] #824915 07/18/07 02:01 AM
4Crawler Offline
Ball joint spacer installation notes:
-http://www.4crawler.com/4x4/ForSale/Docs/BallJointSpacer_HowTo.shtml#4WD
Re: Cheap easy tricks for the stock toyota IFS [Re: IceBlueT] #824916 07/19/07 11:49 AM
G
gt0987 Offline
i was thinkin about leavin the stock rear springs in, or swappin the springs to below the axle with add-a-leafs, for a softer ride while retaining the ride height.
How would this give you a softer ride? You've got the same highly arched spring supporting the same weight and it will be responding to the same road conditions. There's nothing about having the axle above the spring that will give you a better ride relative to placement below the axle.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.5951 MB (Peak: 0.6601 MB) Data Comp: Off Server Time: 2026-10-21 22:06:30 UTC
