Metallic Rattling sound #824973 07/14/07 06:24 PM
thxgoon Offline OP
I just thought I'd post this and see if anyone has had a similar problem and might know what this is.
My truck has had this since I got it but it just keeps getting louder. When I drive my truck there is a loud metallic rattle coming from underneath the truck, it starts at about 2,000 rpm then goes away and comes back with higher rpms. It doesn't affect the driveability any it's just really annoying. Anyone else have this problem? Also, some days it doesn't happen at all, really strange...
Re: Metallic Rattling sound [Re: thxgoon] #824974 07/14/07 08:27 PM
4Crawler Offline
One thing to try is a rubber mallet to tap on things underneath the truck to see if you can duplicate the noise. Might be something loose in the exhaust, for example.
Re: Metallic Rattling sound [Re: 4Crawler] #824975 07/15/07 04:41 AM
Trekker81 Offline
theres a bracket on my truck that was making a rattling noise it was a clamp that bolts on to the transmission might wana check in that area
Re: Metallic Rattling sound [Re: thxgoon] #824976 07/15/07 05:30 AM
lockedstock84 Offline
look at heat shields, or any other thin metal
Have locker, will travel!
Re: Metallic Rattling sound [Re: thxgoon] #824977 07/15/07 05:52 AM
VanillaTHUNDA Offline
If you're running the 22RE with power steering I'll be willing to bet it's the idler pulley. The little bastard HOWLED at about that RPM and sounded like a squealing belt, then rattled and got that metallic sound. I at first thought I spun a cam bearing LOL! Pull that guy off and check the bearing for play.
Re: Metallic Rattling sound [Re: thxgoon] #824978 07/15/07 06:53 AM
Hmmmmm.......
web page + web page =?
Re: Metallic Rattling sound [Re: thxgoon] #824979 07/17/07 09:07 AM
turkbodiddle Offline
look real good at your u-joints had the same problem and found the metal on the bearings had ripped a part.
86 toy 33's custom camo paint dura liner black steels 3 inch lift stock motor
Re: Metallic Rattling sound [Re: turkbodiddle] #824980 07/17/07 09:53 PM
thxgoon Offline OP
Thanks for the replys everyone! I will check some of that out this weekend. It sounds like it's coming from the transmission area so I will definitely look for that clamp. But alas... today my clutch sprung a leak and it's dripping all over my foot. Goodie smile
Re: Metallic Rattling sound [Re: thxgoon] #824981 07/17/07 10:06 PM
W
whitetoy Offline
Mine did that, made a heckuva racket.
Turned out to be a bad catalytic converter.
I guess the stuff inside had broken loose and was rattled around by the exhaust gases.
Rick
1984 4Runner
Re: Metallic Rattling sound [Re: whitetoy] #824982 07/18/07 12:41 AM
dieseltrooper Offline
I just had one start on my 87 4Runner this week. It's the exhaust pipe where it enters the muffler. Rust. I've seem the same thing on my wifes 88 Camry...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6285 MB (Peak: 0.7358 MB) Data Comp: Off Server Time: 2026-06-07 07:04:50 UTC
