ok fellers i have like 60 plus plus oil pressure #825058 07/15/07 12:05 AM
jesoe Offline OP
and oil is blowing up and out of the dipstick is there a quick fix Bigjim? what would i be able to do i like good oil pressure but it always seems way high and truthfully i dont mind going through oil but if i can fix it ill tool around just for the fact of having a nicer jeep <img src="/forums/images/graemlins/scared.gif" alt="" />
what do you prefer over or under suspension for heavy west by god trails
single choice
Votes accepted starting: 07/14/07 05:00 AM
Re: ok fellers i have like 60 plus plus oil pressure [Re: jesoe] #825059 07/15/07 03:05 AM
BigJim Offline
You seem to have posted tow things that prolly are NOT connected!
First off forget about the oil pressure! It is most likely a sender problem and truly NOT the real pressure.
Second Is the rear main seal leaking? Is your PCV in good clean condition? Oil out of the dipstick hole is usually from blowby that cannot escape thru the pcv as it was intended.
PHP: 7.4.33 Page Time: 0.008s Queries: 18 (0.006s) Memory: 0.6011 MB (Peak: 0.6965 MB) Data Comp: Off Server Time: 2026-07-13 03:41:30 UTC
