Roto Hammer Tips? #825223 07/16/07 03:39 AM
kewlynx Offline OP
Aside from safety gear, any special tips with using one of these? I'll be renting the roto hammer.
I'll be drilling holes in 2'x2'x6" pads for a pad/post cabin setup to secure RR ties to them. I know I'll need some masonry epoxy to hold my anchors in place; anything else to consider?
I'll be using bits for cutting rebar, as the pads will already have reinforcement in them.
**ubi apis- ibi salus**
Re: Roto Hammer Tips? [Re: kewlynx] #825224 07/16/07 03:55 AM
rapha Offline
Are the pads already poured? If not, how about setting anchor bolts? If you provide the concrete guy with templates and some kind of setting plan it might be easier. Make sure you buy a good epoxy, like Hilti, and don't drill your holes too large. Depending on the bolt size you are limited on the hole diameter. Just my $.02.
Carlos
'05 Frontier, Auto Tranny, 4.0 V6, 2WD <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Roto Hammer Tips? [Re: kewlynx] #825225 07/16/07 04:08 AM
canuck Offline
I'm in the tool repair business. What size bit are you going to be using and what model of hammer drill is it you are renting along with what is the amp draw. Reason I ask is everybody will use a million miles of extension cord of too small of a gauge and they will totally and I'm mean totally burn out the tool. At a draw of 15 amp and assuming that your voltage is clean (110-115v) you will need a 10 gauge cord at a max length of 25 feet. If you don't follow this you will be buying yourself a burnt out hammer drill from the rental shop with holes still left to drill. A sharp bit is also essential.
Keep the Shiney Side up. Support our troops.
Re: Roto Hammer Tips? [Re: canuck] #825226 07/16/07 04:12 AM
canuck Offline
I forgot to mention, hit rebar with a carbide bit = go to hardware store to buy a new bit.
Re: Roto Hammer Tips? [Re: kewlynx] #825227 07/16/07 04:14 AM
I'd use a rotary hammer drill and wedge anchors instead of drilled holes and epoxy. I've seen some literature on epoxy failures in cold climates. Wedge anchors from Simpson are my choice. I use 10" long .5" diameter anchors. Drill an half inch hole, drop in the anchor, smack with hammer to set the wedge, and tighten the nut. 7" imbedment is recommended, which means you'll have to countersink the nuts in the rr ties. PM me if you need more. I rotohammer about once a week on something, since I do LOTS of concrete construction.
Cutting the rebar with a rotohammer bit is the pits. Try to avoid the rebar mat if possible. How deep is your frost line?
Gloves and long sleeves and a full face shield are nice, but a roto hammer does not throw a lot of eye eaters. Mostly dust. Like concrete buggers?
Re: Roto Hammer Tips? [Re: fasteddy] #825228 07/16/07 04:22 AM
canuck Offline
I'd have to agree with Fasteddy. In cold weather I've also heard that epoxy anchor are a little sketchy. I would also recomend wedge anchors. I think they are easier to work with as well.
Re: Roto Hammer Tips? [Re: canuck] #825229 07/16/07 04:31 AM
California requires epoxy.
No big deal, just use eye protestion and a good carbide. Blow out the holes real well and use epoxy. They also make epoxy capsules you pu tin the holes and they break when you tap the rebar into the hole. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Roto Hammer Tips? [Re: fasteddy] #825230 07/16/07 05:15 AM
kewlynx Offline OP
The pads are precast; I did the math on doing a pour, to include borrowing a friend's cement mixer, and I'm ahead about $600 (you read that right)to go into town and pick 'em up and yank 'em off on my end with a Bobcat. I'm 47 miles from the nearest cement truck, so you can bet I'm not calling them unless it's for a monolithic pour.
Eddy, this is called pad and post construction. The hole is backfilled 4 feet, and compacted to 1 ft above grade. Our frost line here is 6 ft; without snow it's more like 8 ft. <img src="/forums/images/graemlins/zombie.gif" alt="" /> A lot of Lower 48 construction goes by the wayside up here.
After the pads/ties are cinched together, my other hardware will be set up for leveling from time to time. I don't hit gravel in this particular spot until 8 ft. That's a LOT of dirt work for only a 28 x 36 pad.
Am leaning towards wedge anchors; with the RR ties, I'll be using threaded rod to double-nut them in. Thanks for the countersink part; was considering that too. I'm working with 5/8" stock, as we've got a seismic consideration for this. I'll have to ask the industrial hardware guys for sure about my anchor choice before I go layin' out coin. Spent one day running around lining up hardware last week.
I've got dust masks and eye gear. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Am debating about gel gloves, but it's a comparatively small job. Bits will be new; hopefully the next project comes in the form of a GARAGE.
Thanks also for the extension cord tip. IIRC, most of what these guys have are Hilti roto hammers. I was looking for amperage on them, but only found the wattage rating. Will be running off a generator on site to smack this stuff together. Mini shop vac will also be on site for cleaning the holes. Guess I'll stop by again and look at my two choice models and google them for specs to see what I need to use.
Thanks guys! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Roto Hammer Tips? [Re: kewlynx] #825231 07/16/07 05:45 AM
Jim_Paget Offline
Volts x amps = watts, or
Amps = watts/volts, if I remember my high school algebra.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Roto Hammer Tips? [Re: Jim_Paget] #825232 07/16/07 06:25 AM
4xmonty Offline
Thats right
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6444 MB (Peak: 0.7710 MB) Data Comp: Off Server Time: 2026-05-29 22:31:28 UTC
