Water in oil question. #825372 07/16/07 08:12 PM
RandyS Offline OP
I bought a clean 91 Trooper for $300 earlier this year to replace the 89 I've had for 15+ years(well over 300,000 mi, second engine, orig manual trans). I'm just getting around to working on it, there are two problems.
First, there is water in the oil, I pulled the plugs and couldn't see any difference between any of them, I thought I'd at least see some calcium buildup if it was burning it? Has anyone had a leak from a head gasket without it getting into the cylinder? Or is it probably a crack in the block?
I was originally planning on putting a 3.4 in it but I was thinking about just getting it going right now to make sure the tranny and everything in strong before I sell the 89, if there's any problem I'll just rob parts from the 89.
The second is something the guy I bought it from told me about, I haven't run it enough to have it happen. He said when you run it then stop, sometimes it wouldn't start until it cools down. He said it's maybe one time in ten but it seemed to be getting worse when he stopped driving it.
Any ideas?
Thanks
Oh yeah, it's a V6 2.6/2.8(not sure)
1989 Trooper 2.8L
owned since 1992
w/300,000+ mi.
1991 Trooper SE
awaiting 3.4L
Re: Water in oil question. [Re: RandyS] #825373 07/16/07 08:55 PM
Richard Saylor Offline
First, if it's a v6, then it's the 2.8 GM engine.
Second, starting problem when hot sounds just like the typical GM problem with their starters. They get hot where they are and don't work well like that. Let them cool down and they usually work just fine. They make heatshields for them. Local autoparts stores will have them.
Plugs, if it's getting water/coolant into the cylinder, the affected cylinder's plug will be considerably cleaner than the rest due to the water turning into steam and effectively steam cleaning the plugs.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Water in oil question. [Re: Richard Saylor] #825374 07/16/07 10:43 PM
RandyS Offline OP
All the plugs are very clean, not at all like a 155,000mi engine should have. They're not new though, they definately have some miles on them, the electrodes have some serious rounding. There isn't any water running though the intake manifold that could be getting in both sides is there?
It turns over fine, there's just nothing there. More like it's either missing spark or fuel/air.
1989 Trooper 2.8L
owned since 1992
w/300,000+ mi.
1991 Trooper SE
awaiting 3.4L
Re: Water in oil question. [Re: RandyS] #825375 07/16/07 10:55 PM
Yep, I'd say the starter is overheating ...
84 Honda XL185S
Re: Water in oil question. [Re: Richard Saylor] #825376 07/16/07 11:25 PM
RandyS Offline OP
Really?
1989 Trooper 2.8L
owned since 1992
w/300,000+ mi.
1991 Trooper SE
awaiting 3.4L
Re: Water in oil question. [Re: RandyS] #825377 07/17/07 12:03 AM
What it is, is with the exhaust sitting so close to it, the starter just acts like a big heat sink. When the starter gets overheated because of that, it doesn't like to work. I noticed the same thing on the one I've got. Didn't do it with the previous one, but the starter that's on it now seems to be doing it. Hasn't gotten to the point of not turning over, but it gets really slow and even to the point of where I wonder if it is going to start. But every time the engine cools down a bit, it's fine.
84 Honda XL185S
Re: Water in oil question. [Re: Richard Saylor] #825378 07/17/07 02:01 AM
Ed Mc Offline
Certainly could be the starter, check all your connections including neg cable to block.
The water in oil Most Definitely could be coming from a leaking intake manifold gasket, it's what killed the Trooper I bought a few years back and turned into a 'stroker' 3.1.
I'd be more inclined to think leaking intake rather than head gasket, since you say all the plugs read about the same. A blown head gasket would typically give you a few abnormal readings in the blown cylinder(s).
BTW if the coolant has been there for some time it's probably done the bearings damage already, that 3.4 in your other post is probably a good idea!
G'luck.......ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Water in oil question. [Re: Ed Mc] #825379 07/17/07 05:58 PM
mlclark Offline
Isuzu Moderator
I think we have some group-think going on here: <img src="/forums/images/graemlins/smile.gif" alt="" />
But, the problem was described as:
I am not an expert by far, but if the engine is turning over, I would say that the starter is probably not overheated. I would suspect there is a problem somewhere else. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Water in oil question. [Re: mlclark] #825380 07/17/07 06:11 PM
... But, the problem was described as:
Michael
This is what I was going off of: "He said when you run it then stop, sometimes it wouldn't start until it cools down."
And since he hasn't run it enough himself to have this problem, to me that sounds like the typical GM starter overheat problem.
84 Honda XL185S
Re: Water in oil question. [Re: Richard Saylor] #825381 07/29/07 06:45 AM
mthunderwolf Offline
I have have been experiencing the same problem with my 91 2.8 hesitating when I stop and then try to start it! I was wondering what was causing this but with the temps being around 100 the past few weeks it makes sense and Richard...once again you solved one of my problems! Thanks! Now I will go and get a heat shield for my starter! <img src="/forums/images/graemlins/wink.gif" alt="" />
This also has me thinking about the problems with the 86 2.3L that I just bought that has been sitting for 3 years. I was told that it was a cracked block but I changed all the fluids and it starts okay but won;t run long and I have a lot of white smoke coming out the exhaust. Now that you guys mentioned the possible leaking of the intake gasket I noticed that there are some new bolts on this one. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I am planning on replacing the head and gasket. It seemed to run smoothly when we cranked it and all the plugs were pretty dirty. Suggestions? thoughts?
ThunderWolf
91 Trooper 2.8 v6
86 Trooper 2.3 4cyl
no lift kits... yet!
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6526 MB (Peak: 0.7775 MB) Data Comp: Off Server Time: 2026-11-02 12:29:22 UTC
