calmini no longer makes UCA's for early troopers. #825495 07/17/07 05:41 PM
Shovel Offline OP
like the title says.. just got off the phone with 'em.
just an FYI for folks.
Re: calmini no longer makes UCA's for early troopers. [Re: Shovel] #825496 07/18/07 12:03 PM
ZenderHead Offline
I wish I knew what UCA stood for.. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
1994 Isuzu Rodeo LS - Straight Axle
1992 Isuzu Trooper - Stock
Re: calmini no longer makes UCA's for early troopers. [Re: ZenderHead] #825497 07/18/07 12:57 PM
ehess Offline
Upper Control Arm.
From whay I've seen of Calmini's products, it's no great loss. <img src="/forums/images/graemlins/ignore.gif" alt="" />
-Erik
1995 Trooper SOHC, 255/85R16 Dunlop Mud Rovers, OME 912, 2" Daystar coil spacer, torsion bar crank
Tera-Low in the T-case and 5.38's Rear LSD
Re: calmini no longer makes UCA's for early troopers. [Re: ehess] #825498 07/18/07 01:23 PM
BigSwede Offline
They general make very nice products (the rear bumper I have is an example)...IF you can get them to make them for you. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
But the UCAs never did seem to provide much bang for the buck.
Serenity now!
Re: calmini no longer makes UCA's for early troopers. [Re: BigSwede] #825499 07/18/07 04:17 PM
Shovel Offline OP
Good products. Disappointing customer service.
Re: calmini no longer makes UCA's for early troopers. [Re: Shovel] #825500 07/18/07 11:27 PM
V
VOLTRON Offline
if you install the UCA from calmini do you still have to crank the torsion bars or do they remain at factory setting?
NOT ALL WHO WANDER ARE LOST
Re: calmini no longer makes UCA's for early troopers. [Re: VOLTRON] #825501 07/19/07 12:37 AM
Richard Saylor Offline
All the new control arms were for, was to allow the alignment to be brought back to within specs. They don't lift any at. You have to still crank the torsion bars to achieve lift.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: calmini no longer makes UCA's for early troopers. [Re: Richard Saylor] #825502 07/19/07 01:22 AM
Shovel Offline OP
heh, ultimately it's a moot point.
People who have them, have them... and people who don't, won't ever need to worry about it. Just like that $400 bolt-on solid front axle swap kit.
Re: calmini no longer makes UCA's for early troopers. [Re: Shovel] #825503 07/19/07 03:04 AM
BirdShocks Offline
Does anyone else make'em?
Re: calmini no longer makes UCA's for early troopers. [Re: BirdShocks] #825504 07/19/07 03:25 AM
I don't know of anyone else that makes (made) them besides Calmini.
FWIW, some (most) of us here just do the ball joint flip with or without a spacer. All that involves is relocating the ball joint from the top of the arm to the bottom of the arm. Not hard, just unbolt and take it out and rebolt it in from the bottom. If need be, add a 1/4" spacer that Matt at Indy4x sells to allow it to be aligned to specs.
84 Honda XL185S
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6353 MB (Peak: 0.7586 MB) Data Comp: Off Server Time: 2026-06-13 10:53:12 UTC
