tips on driving with auto locker in rear #825510 07/17/07 06:06 PM
cktoy Offline OP
anybody have any tips on driving with an aussie locker.sometimes at low speeds (parking lots) in turns it bucks and grabs.what causes it to engage or disengage?
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: tips on driving with auto locker in rear [Re: cktoy] #825511 07/17/07 06:44 PM
4Crawler Offline
Sounds like pretty normal behavior. Usually if you are light on the gas while turning, that will help. Also, avoid getting on and off the gas in turns. Why? On the gas, the outside wheel unlocks in a turn and the inside wheel drives. Off the gas and the inside wheel unlocks and the outside wheel locks up. It is those transitions between inside and outside wheel that causes the bucking, since the wheels are rotating at different speeds. So if you can coast into a turn then apply the gas smoothly one time as you come out of the turn, that will help to minimize the bucking.
Re: tips on driving with auto locker in rear [Re: cktoy] #825512 07/17/07 07:32 PM
CJMT100 Offline
You can use the clutch if you have a stick, that or keep constant gas or coast in, only real ways to do it imho.
Re: tips on driving with auto locker in rear [Re: 4Crawler] #825513 07/17/07 08:39 PM
cktoy Offline OP
thanks guys,just what I was looking for
oh what a feeling:
84 supra yard art
Re: tips on driving with auto locker in rear [Re: cktoy] #825514 07/18/07 06:47 AM
O
ovrrdrive Offline
I find that if I try to clutch in and coast through a turn it bucks from start to finish but if I give light gas and drive through it it's smooth as silk.
Re: tips on driving with auto locker in rear [Re: ovrrdrive] #825515 07/18/07 05:50 PM
cktoy Offline OP
if I clutch before it starts bucking not too bad but if I clutch after it starts it gets worse
oh what a feeling:
84 supra yard art
Re: tips on driving with auto locker in rear [Re: cktoy] #825516 07/18/07 10:56 PM
O
ovrrdrive Offline
How long have you had it in?
Re: tips on driving with auto locker in rear [Re: ovrrdrive] #825517 07/19/07 09:10 PM
cktoy Offline OP
got about a thousand miles on it
oh what a feeling:
84 supra yard art
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6201 MB (Peak: 0.7013 MB) Data Comp: Off Server Time: 2026-06-07 06:55:07 UTC
