help!!! turn signals fail to work #825637 07/18/07 09:14 AM
8
88turbomontero Offline OP
ok well my turn signals have offically died... at first they worked fine, then they only worked if i kinda pushed the lever towards the dash. well now they don't work at all.
i need this car to drive to work so the whole no blinker thing is making me feel like an ass when changing lanes, so this needs to be fixed asap.
so my questions are:
where should i start first in my search for the culprit?
are there any parts that are prone to failure in the turn signal circuit?
oh and it might help to know i have a 88' 4 cyl. montero
thanks in advance.
cars:
88' montero SWB (turbo 2.6l project)
03' S2000w/hardtop (daily ride)
91' crx dx (my never ending project)
Re: help!!! turn signals fail to work [Re: 88turbomontero] #825638 07/18/07 03:05 PM
hazy_daze Offline
First, use hand signals, that'll keep you legal. Next, it sounds like the multi switch in the column is crapping out. Take it out, clean the contacts, see if that helps. Use some contact cleaner (electrical parts cleaner), maybe some real fine emory cloth, take it apart carefully, making mental notes or physical drawings of how it goes back together. Or, just buy another one to throw in there <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: help!!! turn signals fail to work [Re: hazy_daze] #825639 07/18/07 04:05 PM
CapnCrunch Offline
Also do the same with your hazard switch.
Do they come on at all (i.e., come on, stay on, and not blink) when you engage the turn signal lever to one way or another or do they not come on at all?
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: help!!! turn signals fail to work [Re: CapnCrunch] #825640 07/18/07 09:42 PM
89montero Offline
if they stay on it could be your flasher, if it is they're less than $20 to replace.
1989 Montero 4dr V6 3.0l
Re: help!!! turn signals fail to work [Re: 89montero] #825641 07/18/07 10:20 PM
torquemonster Offline
yes...if nothing happens it could be your hazard light switch...if that is unplugged or broken you will have no signal lights or anything.
Re: help!!! turn signals fail to work [Re: torquemonster] #825642 07/19/07 03:03 AM
That hazard swith is a pisser, ain't it? My hazards would only work on one side. And my blinkers didn't seem to have the right "timing." This was the third of the switches from my donor trucks from way back now.
I picked up a very clean switch from fleabay and threw it in today. All is well... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: help!!! turn signals fail to work [Re: MontyMcV] #825643 07/19/07 07:54 AM
8
well they don't work at all, they don't light up or anything. also when i was in the slight push towards dash stage they would sometimes skip a blink.
so is there way i can test the hazard switch?
thanks matt
cars:
Re: help!!! turn signals fail to work [Re: 88turbomontero] #825644 07/20/07 04:02 AM
8
also thought i would say that the hazard lights work fine.
so is the blinker switch(lever thing) broken?
cars:
Re: help!!! turn signals fail to work [Re: 88turbomontero] #825645 07/20/07 12:28 PM
hazy_daze Offline
Yes, that's why I put the post that I did at first <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: help!!! turn signals fail to work [Re: hazy_daze] #825646 07/21/07 12:46 PM
Y
yankneck696 Offline
I fixed my Hazzard switch with tooth picks & superglue... Very common issue with them is to have the rocker pivots break. I just got it to where all the lights work & superglued it into position.
THne got a road flare kit & a flare gun ( outta my old boat ) just for added insurance on the trail ( If the Cell phone, CB & Ham radio fail me ).
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6348 MB (Peak: 0.7419 MB) Data Comp: Off Server Time: 2026-06-07 06:57:23 UTC
