Page 3 of 8 1 2 3 4 5 6 7 8
Re: Red Chili 2.5 [Re: TexJeff87] #825697 07/21/07 03:41 AM
Snowtoy Offline
Bummer man. I can relate.
Snow, I see your point, but it's not economically feasible for me to do a body swap. So I'll wheel it beat. But I gotta get a cage first.
Anyhow, good luck with it Bill.
I understand about the time/$$ involved with body swaps, but if the A-pillars are damaged it really becomes more of a safety issue than ca cosmetic one. The integrity of the oem safety cage is gone once you crush an A-pillar. Your only real options then are a cab swap, or an internal/external cage.
If the dents are just cosmetics, some cheap body tools, light bondo, and some paint can do a lot for the appearance of your beater. It will also give you a way of learning/harnessing your body skills, so if you ever have to fix a dent on your daily you can save yourself some $$.
Re: Red Chili 2.5 [Re: Snowtoy] #825698 07/23/07 07:44 PM
Red_Chili Offline OP
Toyota Section Staffer
A-pillars *can* be repaired, but you'd better have a good shop do it. Another risk is loss of corrosion protection, I am told. Not a factor for a "trail beater", but I don't like trail beaters.
The guy fixing my truck looked at another job that had opened rear fenders, and he commented that there was so much welding to make that happen that much of the OEM corrosion protection was toast, with no way to make it as protected as original.
I don't claim to fully understand, but the guy knows his stuff and stands behind it...
-Bill
Re: Red Chili 2.5 [Re: Snowtoy] #825699 07/23/07 08:14 PM
TexJeff87 Offline
My a-pillars are done. I bent them back out with my hi lift...at this point it's a matter of getting together the $$ together to buy the cage from 4XInnovations.
Re: Red Chili 2.5 [Re: Red_Chili] #825700 07/23/07 09:08 PM
bkg Offline
OEM corrosion protection, yes... but why can't "after market" be just as good, especially for a non DD vehicle? A friend of mind did an amazing job on his rear fenders. I think the rest of the truck will rust around them.
Brian K. Gallus
Re: Red Chili 2.5 [Re: TexJeff87] #825701 07/23/07 09:19 PM
Snowtoy Offline
Exactly, almost good enough isn't, unless of course you are running an internal or external cage.
TexJeff87
Another option than a complete body swap is to replace the upper section of the Runner's cab, from the cowel up. Look for a runner that has the rear crushed or a lot of rust.
If you cant't find a Runner, you could use a truck's cab, and turn it into a convertable(old LC style) with the internal cage. If the rear top was damaged in your roll, a bikini top would be easy to make for the rainy season and colder months there in Texas
Re: Red Chili 2.5 [Re: bkg] #825702 07/24/07 05:22 PM
Yeah, I deferred to Terry doing the work. I have seen good looking fender re-dos, but got a chance to see one pre-painted and it gave me pause. Lots of Bondo. LOTS of welding on the sheetmetal. Lots of buckling, and the guy doing it was really good too.
The best way is to get a foldover crimp going, with spot welds, like the factory does it. Very difficult to do manually.
Oh, and I am about half done with my new half door. This one will be better than the original, since I've been doin' some learnin' twixt then and now. <img src="/forums/images/graemlins/pfft.gif" alt="" />
-Bill
Re: Red Chili 2.5 [Re: Red_Chili] #825703 08/10/07 09:15 PM
8
87XJCO Offline
I'm doing the work on this one and it's progressing pretty well
Inner quarter panel replaced on donor body
Outer quarter panel in progress
Doors and hood in primer
Body in primer
Re: Red Chili 2.5 [Re: 87XJCO] #825704 08/10/07 09:23 PM
Well howdy Terry! You stalking me? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
BTW all, Terry is the guy who married an XJ that had been rolled with a Toy pickup and ended up with a Toyomanche. Sorta.
Dirty Harry would be proud... <img src="/forums/images/graemlins/evil.gif" alt="" />
-Bill
Re: Red Chili 2.5 [Re: Red_Chili] #825705 08/22/07 08:27 PM
It's Reeeeeeeeeeeeed...........
Did a bit of engine compartment reinstallation of all my hoo-haw and bits. Saving Terry a little hair pulling. Which, if you ever saw Terry, is obviously a precious commodity to him!
It's coming along. If not in time for much wheeling <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/baby.gif" alt="" />, at least it will be fully configured for hunting...
Oh, and those wheels are loaners from Terry... <img src="/forums/images/graemlins/evil.gif" alt="" />
-Bill
Re: Red Chili 2.5 [Re: Red_Chili] #825706 08/22/07 11:54 PM
Staceman Offline
Yes..... It is.
Looks great man!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6505 MB (Peak: 0.7790 MB) Data Comp: Off Server Time: 2026-05-29 22:27:16 UTC
