front knuckle diagram #825839 07/18/07 10:43 PM
F
frankinpa Offline OP
I'm looking for a exploded view of the front hub on a 89 isuzu. I read in the manual that the front wheel bearing is one piece and has not adjustments? is this right.
Re: front knuckle diagram [Re: frankinpa] #825840 07/18/07 11:54 PM
mlclark Offline
Isuzu Moderator
Nope. You read wrong. The front wheel bearings are not sealed units. Pre-load is adjusted via the spindle nut.
I don;t have a diagram for you, but it is your typical 4wd spindle and hub arrangement.
Michael
Re: front knuckle diagram [Re: mlclark] #825841 07/19/07 07:40 AM
lttlbddy Offline
Re: front knuckle diagram [Re: lttlbddy] #825842 07/19/07 01:26 PM
F
Does this go for 4wd also? I should have stated it was a 4x4 amigo
After i read that i checked advace auto's site and they only listed 2wd bearings no reference to 4wd. Then i checked autozone .com and they listed 1 bearing for somthing in the range of 80.00usd. Next question is there a special socket for the #8 locknut? Or does sombody have a OTC part number?
Re: front knuckle diagram [Re: frankinpa] #825843 07/19/07 03:22 PM
lttlbddy Offline
I use a crank tool for my bicycle to loosen the nut or a screw driver and my palm.
I believe the above is a 4wd version. The specs I used were for a 1989 Trooper which only came as 4wd.
I got that diagram from myisuzuparts.com
For some reason they don't list the Amigo but the parts are all the same.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-06-21 13:41:23 UTC
