4 lo #825844 07/18/07 11:20 PM
94rodeo94trooper Offline OP
I just bought a 78 cj-7. I was wondering about 4 lo I am new to jeeps the only thing i see is a switch in the glove box which I thing is kind of a locker please advise me if there is 4 lo or not
http://www.tacomaterritory.com/forum/showthread.php?t=43190http://i148.photobucket.com/albums/s13/jerm5591/haspen5.jpg
Re: 4 lo [Re: 94rodeo94trooper] #825845 07/19/07 12:38 AM
F
Fred Blackstone Offline
You may not have a low range! I had a 79 CJ-7 when I was a kid. Typically, the quadratrac has a shift lever on the floor if you have 4 Low. The button in the dash is for posi-lock. It's been too many years, I'll let CJ guys tell you more of what you possibly have in your new Jeep. Have fun with your CJ!
Re: 4 lo [Re: 94rodeo94trooper] #825846 07/19/07 04:55 AM
BobRowe Offline
Two questions:
1. Do you have a shift lever for the transfer case?
2. Does the switch in the glove box look OEM or does it look like a previous owner installed it?
Re: 4 lo [Re: BobRowe] #825847 07/25/07 11:02 AM
no shift lever just switch in glove box. I am looking for a tub and frame if anybody knows were there is on cheap mine rusted worst than i thought.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6034 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-10-24 08:16:37 UTC
