Spark Plugs - so hard for 2003 V6 #825924 07/19/07 04:08 AM
Superman Offline OP
Is it me or is it really hard to change the spark plugs for 2003 V6?
Some of my other cars, the spark plugs are right on top of the engine.
I know what tools to use but the length of the socket wrench has to be the right size. Anyone has pictures of the tools and length that you use?
Also, I was able to locate 3 on the driver side. Are the other 3 under some type of square sensors? I know they are under the air intake.
Any tips on the spark plug on the driver side that is close to the window? That one seem really hard to get to.
I am using Bosch and they recommend .44.
Thank You
Clark
Tacoma PreRunner Double Cab V6 Automatic
3.4-liter V6 TRD
Re: Spark Plugs - so hard for 2003 V6 [Re: Superman] #825925 07/19/07 08:21 AM
Coyotekid Offline
Thank You
I've done MANY tune ups on the 5VZFE..
Don't be afraid to move stuff out of your way to get to the spark plugs..it'll all bolt right back into place <img src="/forums/images/graemlins/smile.gif" alt="" />
I use a 6 inch extension, on a 3/8' drive wratchet, and have never ran into any problems..
Like I said before, don't be scared to move things out of the way to get to where you need to work on!
-Dano-
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Spark Plugs - so hard for 2003 V6 [Re: Superman] #825926 07/19/07 08:43 AM
humanoid Offline
Look in our maintenance section, has a great DIY:
http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep3.html#plugs
or you can look here too:
http://4runners.org/writeups/sparkplugs/index.html
I would return those Bosch plugs ASAP. Our truck don't play well with those plugs. Go to the $tealer and get some OEM Denso or NGK plugs or you'll be sorry that you didn't.
Re: Spark Plugs - so hard for 2003 V6 [Re: Superman] #825927 07/19/07 04:07 PM
Mark in AZ Offline
Toyota Moderator
...and they recommend .44.
Just to clarify, that should be .044"
X2 on using the factory plugs vs. anything else
Oh, and that first writeup is the best one <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" /> LOL
Exploring in a T4R Ltd V8
Re: Spark Plugs - so hard for 2003 V6 [Re: Superman] #825928 07/19/07 04:35 PM
azrain Offline
Back when I had my 4Runner (somewhat similar engine bay and placement) I had to use a handful of extensions and a u-joint to get the plug nearest the firewall out of the hole.
I recommend using a good anti-seize and the "vacuum line" trick to start the plugs back in the head. I have no idea what the torque spec is, but snug and a quarter turn worked fine on my 3.4 V6. Nothing sucks more than trying to heli-coil a stripped spark plug hole. Well, almost nothing anyhow.
Re: Spark Plugs - so hard for 2003 V6 [Re: Coyotekid] #825929 07/19/07 10:07 PM
Adam F Offline
Ditto, and Ditto. Easiest V6 spark plug change I've EVER done.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6138 MB (Peak: 0.7027 MB) Data Comp: Off Server Time: 2026-06-22 06:14:04 UTC
