Unlocked hubs but yoke still spinning #825936 07/19/07 04:19 AM
L
Locked_Solid_Toy Offline OP
I had 4.88 yukon gears and a detroit truetrac installed in my front third member of my '85 truck. i reinstalled the third member and put the front end back together. but now even when my hubs are unlocked the yoke on the thirdmember still spins when i just roll or coast the truck. is it suppose to do this what is wrong with it. thanks for any help
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: Unlocked hubs but yoke still spinning [Re: Locked_Solid_Toy] #825937 07/19/07 09:24 AM
Adam F Offline
You probably either installed the hubs improperly, or used too much grease inside the hubs and they are sticking. Tear them back apart and re-check them. I have some links on my site to some good rebuilds
http://home.4x4wire.com/adamf/88/hubrebuild.htm
97 4R, stock, daily driver
Re: Unlocked hubs but yoke still spinning [Re: Locked_Solid_Toy] #825938 07/19/07 11:51 AM
A
ashbyota Offline
Put your transfer case in 2HI!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Happy Wheelin' <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: Unlocked hubs but yoke still spinning [Re: Locked_Solid_Toy] #825939 07/20/07 02:58 PM
OOP'S Offline
Many non-full time 4WD vehicles do it. It has something to do with all the gears that are turning. I bet if you put all four wheels off the ground, started it up in gear you could grab the d-shaft and stop it. If everything is set up right, it is not really under power.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Unlocked hubs but yoke still spinning [Re: OOP'S] #825940 07/20/07 11:27 PM
Dingman Offline
Correct. I've seen several of my vehicles do it. I double checked and nothing was broken or locked, it was just the grease\gear friction that can make it turn.
Now, it may have been too much grease on my Toyotas but my GM and Fords are totally OEM and they do it too.
EDIT: But I'm not saying you didn't put somethign back together wrong. smile
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
Re: Unlocked hubs but yoke still spinning [Re: Dingman] #825941 07/22/07 06:25 PM
salvo Offline
i have never used grease in my hubs.. learned this from a buddy... when i work on my hubs i soak the gears in a heavy gear oil and reasemble them... have never had any trouble with this procedure and they have never rusted or goten stuck on me ...i usually pull them apart every year and redo them when im checking things out
Re: Unlocked hubs but yoke still spinning [Re: OOP'S] #825942 07/22/07 07:30 PM
RatLabGuy Offline
My truck does axectly as oops has stated.
And yess, I've probably over greased it, too.
Question Reality.
Re: Unlocked hubs but yoke still spinning [Re: RatLabGuy] #825943 07/22/07 08:46 PM
OOP'S Offline
Climb under without it running; see if you can turn the d-shaft, tranny in neutral t-case in 2 high. If it turns, you are good to go. If it does not turn, break out the wrenches. I would start with the hubs first.
David Fritzsche
Roseville, CA
Re: Unlocked hubs but yoke still spinning [Re: OOP'S] #825944 07/22/07 09:12 PM
L
yea i got it fixed i had put the hubs back together wrong it works the way it is supposed to know. thanks everyone
Re: Unlocked hubs but yoke still spinning [Re: Locked_Solid_Toy] #825945 07/22/07 10:53 PM
Adam F Offline
Good to hear!
I was right! <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6405 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-11-02 12:30:38 UTC
