Dana 44 outer wheel bearing #825959 07/19/07 02:03 PM
HCMP Offline OP
Hey everybody,
Are you guys and gals getting these pressed on using an actual press or is the shade tree mechanic method of pounding it on using the carcass of the old bearing and a hammer sufficient?
My e-brake locked up in the driver side rear wheel and the heat smoked the seal and bearing.
Literally smoked.
Thanks,
--jeremy <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Dana 44 outer wheel bearing [Re: HCMP] #825960 07/20/07 03:06 AM
RobG Offline
i gather you're talking about the wheel bearing on a rear D44. .. I use a long pipe sleeving the axle shaft and a BFH to drive it home... it can be done without a press.
-Rob
Re: Dana 44 outer wheel bearing [Re: HCMP] #825961 07/20/07 05:14 AM
Gizzy42 Offline
Geez, glad that didnt happen to mine. My drivers side e-brake cable went bad and kept sticking on. It would eventually pop loose but I know that brake go pretty warm. Jerry hooked me up with another cable off an '01 rodeo and it got it changed out last week. Pain to do on 2nd gen rodeos, have to drop the tank to get to one of the brackets.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Dana 44 outer wheel bearing [Re: HCMP] #825962 07/20/07 12:08 PM
HCMP Offline OP
Sweet. Thanks, Rob.
Re: Dana 44 outer wheel bearing [Re: HCMP] #825963 07/21/07 09:14 PM
94rodeo Offline
I too use the long pipe sleeve and it works just fine.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6063 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-05-29 18:58:57 UTC
