Questions about changing the coolant....
#826006
07/19/07 10:18 PM
Changing the coolant on my '03 Camry. The tech at the local Toyota dealer said that using DEX-Cool would be fine. Do these systems really need to be flushed thoroughly before putting in fresh coolant? If DEX-Cool mixes with the old Toyota coolant will it hurt anything?
Also, my truck has an aluminum radiator with the old green coolant...I should be running DEX-Cool with an aluminum radiator should't I?
Thanks for any input!
Re: Questions about changing the coolant....
[Re: 93xtra]
#826007
07/19/07 10:33 PM
Dex-cool? No way. It doesn't mix with anything. Besides, It's been known to clog up GM radiators. No way would I put it in my Toyota. Your Camry came with Toyota red coolant, thats what you should put back in it.
I'd put Toyota red in your truck too. Either that or green.
[Re: Adam F]
#826008
07/19/07 11:57 PM
Yeah dont use dexcool. Just use whatever coolant was in there before, if it was red use red if it was green, use green. If you're gonna be switching coolants then make sure you flush all the old stuff out. Keep flushing it out until the water runs clear. Ive been using prestone green in mine and it works just fine. Once a year i'll drain and flush the radiator and the block, and then fill'er back up with a 50/50 mix.
[Re: mqm]
#826009
07/20/07 02:33 AM
Don't forget to set the temperature control to hot before you do the flush, so that you open up the heater core and flush it too.
[Re: Adam F]
#826010
07/20/07 02:41 PM
Also, use DISTILLED water, NOT regular tap or hose water.
[Re: Staceman]
#826011
07/20/07 09:22 PM
what does the tap water do?
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
[Re: cktoy]
#826012
07/20/07 09:58 PM
It tyipcally has lots of minerals in it. They will precipicate out in the cooling system and leave deposits inside.
[Re: 4Crawler]
#826013
07/21/07 12:28 AM
Distilled <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
My 85 2WD water pump is Factory Original... Thank you very much <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: 4Crawler]
#826014
07/21/07 12:55 AM
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />ok ,I should have thought of that.thanks
