Questions about changing the coolant.... #826006 07/19/07 10:18 PM
93xtra Offline OP
Changing the coolant on my '03 Camry. The tech at the local Toyota dealer said that using DEX-Cool would be fine. Do these systems really need to be flushed thoroughly before putting in fresh coolant? If DEX-Cool mixes with the old Toyota coolant will it hurt anything?
Also, my truck has an aluminum radiator with the old green coolant...I should be running DEX-Cool with an aluminum radiator should't I?
Thanks for any input!
Re: Questions about changing the coolant.... [Re: 93xtra] #826007 07/19/07 10:33 PM
Adam F Offline
Dex-cool? No way. It doesn't mix with anything. Besides, It's been known to clog up GM radiators. No way would I put it in my Toyota. Your Camry came with Toyota red coolant, thats what you should put back in it.
I'd put Toyota red in your truck too. Either that or green.
97 4R, stock, daily driver
Re: Questions about changing the coolant.... [Re: Adam F] #826008 07/19/07 11:57 PM
mqm Offline
Yeah dont use dexcool. Just use whatever coolant was in there before, if it was red use red if it was green, use green. If you're gonna be switching coolants then make sure you flush all the old stuff out. Keep flushing it out until the water runs clear. Ive been using prestone green in mine and it works just fine. Once a year i'll drain and flush the radiator and the block, and then fill'er back up with a 50/50 mix.
Re: Questions about changing the coolant.... [Re: mqm] #826009 07/20/07 02:33 AM
Adam F Offline
Don't forget to set the temperature control to hot before you do the flush, so that you open up the heater core and flush it too.
Re: Questions about changing the coolant.... [Re: Adam F] #826010 07/20/07 02:41 PM
Staceman Offline
Also, use DISTILLED water, NOT regular tap or hose water.
Re: Questions about changing the coolant.... [Re: Staceman] #826011 07/20/07 09:22 PM
cktoy Offline
what does the tap water do?
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Questions about changing the coolant.... [Re: cktoy] #826012 07/20/07 09:58 PM
4Crawler Offline
It tyipcally has lots of minerals in it. They will precipicate out in the cooling system and leave deposits inside.
Re: Questions about changing the coolant.... [Re: 4Crawler] #826013 07/21/07 12:28 AM
Staceman Offline
Distilled <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
My 85 2WD water pump is Factory Original... Thank you very much <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Questions about changing the coolant.... [Re: 4Crawler] #826014 07/21/07 12:55 AM
cktoy Offline
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />ok ,I should have thought of that.thanks
oh what a feeling:
84 supra yard art
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6264 MB (Peak: 0.7291 MB) Data Comp: Off Server Time: 2026-07-15 07:16:59 UTC
