front brake pads? #826154 07/20/07 08:06 PM
Jonno Offline OP
Hey guys,
I have a 91 Paj and I'm tryign to figure out which brake pads to order for the front. I changed the back pads using the 92 Montero but there seems to be confusion with teh front pads. any suggestions (other than taking them off and measuring)?
Re: front brake pads? [Re: Jonno] #826155 07/21/07 02:20 AM
hazy_daze Offline
If you have 2 piston calipers, the GenII should be the right pad. The GenI's came with 1 pots <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: front brake pads? [Re: Jonno] #826156 07/21/07 06:00 PM
Pajerist Offline
I will need them too soon or late...
Please, post part# for rear pads!
Where did you get them? How much?
Cheers,
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: front brake pads? [Re: Pajerist] #826157 07/26/07 08:24 PM
Jonno Offline OP
Pajerist,
I just moved and my reciepts are in a box 'somewhere' in my house. As soon as I find them i'll post the part numbers. I did get them from NAPA asking for 1992 Montero rear pads. what a breeze to replace. I'm hoping the fronts go just as smooth.
Re: front brake pads? [Re: Jonno] #826158 07/26/07 10:53 PM
Pajerist Offline
Thanks and good luck wiht front replacement!
Cheers,
www.ivoac.ca
Re: front brake pads? [Re: Pajerist] #826159 07/27/07 12:59 AM
torquemonster Offline
weird because my GEN II has single piston front brakes...they are HUGE though.
Re: front brake pads? [Re: Pajerist] #826160 07/28/07 06:26 PM
hazy_daze Offline
Looking up the part #'s on a slow, rainy day at NAPA <img src="/forums/images/graemlins/lol.gif" alt="" />
For 92 Montero, these are the Ceramix #'s.
Front NAPA # CMX7412
Rear NAPA # CMX7447
Hope that helps <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: front brake pads? [Re: hazy_daze] #826161 08/02/07 03:45 AM
Pajerist Offline
Thanks! Sure it helps!
Cheers, <img src="/forums/images/graemlins/cheers.gif" alt="" />
www.ivoac.ca
Re: front brake pads? [Re: Pajerist] #826162 08/09/07 05:14 AM
Jonno Offline OP
OK, so I finally got front pads on the Paj --- so easy! And I thought Chevy disc brakes were easy to work on. One bolt and the caliper rotates up and out of the way! the NAPA part number that I used is AE7241M.
Re: front brake pads? [Re: Jonno] #826163 08/09/07 07:59 PM
hazy_daze Offline
Interesting, that's the part number for the GenI (old body style)
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6406 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-11-02 21:48:40 UTC
