Distributor question 88 SWB 2.6 #826177 07/20/07 11:00 PM
bigroxydog Offline OP
I just finished installing a new rebuilt engine into my 88 2.6L Auto SWB. I have only two more things to do before I try to start the motor. I need to install the distributor and attach the valve cover. Can some one give me some advice on what I need to do regarding finding or fixing to No. 1 cylinder TDC so that when I install the distributor the timing is correct so the motor fires correctly. The factory manual states to turn the camshaft sprocket's timing mark and the timing chain's timing mark so they are in alignment. I quite don't understand what that means.
Also I plan to run the engine with 30 weight oil for 20 minutes and then drop the oil and filter; after that I will refill with synthetic for 500 miles and change again. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Distributor question 88 SWB 2.6 [Re: bigroxydog] #826178 07/20/07 11:51 PM
powerRam50 Offline
dont run synthetic for at least 1000 miles.go ahead and run it for 20 min then change the oil but use 30wt for the first 1000 miles.it helps in the break in of the moter.
Re: Distributor question 88 SWB 2.6 [Re: powerRam50] #826179 07/20/07 11:59 PM
Thank you for that advice.
Re: Distributor question 88 SWB 2.6 [Re: bigroxydog] #826180 07/21/07 01:19 AM
For timing the engine:
1. Rotate the engine until the notch in the back rim of the crank pulley is aligned with the TDC mark on the timing cover. Since the cam turns at half the rate of the crank, There are two places in the firing order this happens, at tdc for #1 and at tdc for #4 (firing order is 1-3-4-2). To check which one you are at (and to rough check correct timing chain alignment), at tdc on #1 (where you want to be), both #1 valves are closed and the cam lobe points away from the valve. The cam sprocket dowel pin hole (about an inch out from the center of the sprocket) will be just a hair short of straight up 12:00 oclock. The hole for this dowel pin goes thru the distributor gear, the cam sprocket, and into the end of the cam.
2. The engine is now dead on TDC on #1 cylinder. Now you install the distributor in time with the engine. Distributor in hand, locate a drilled dimple on the distributor gear, and rotate the distributor shaft until that dimple aligns with a cast mark on the distributor shaft case. Holding the distributor thus aligned, insert the dizzy into the head with the adjustment slot aligned with and centered on the hold down stud in the head. When the dizzy gear begins to engage with the dizzy drive gear on the cam, let the dizzy shaft begin to turn as the helical gears engage, keeping the dizzy body centered on the adjustment stud as you sock the dizzy home all the way. The dizzy rotor should be pointed at the location of the #1 plug wire tower stud in the cap, or roughly at 10 o'clock, right about the cap clip spot. #3 should be at about 1 o'clock, #4 at about 4 o'clock, and #2 at about 7.
That should get it close enough to run, set the idle speed, and set the idle timing with the light. Hope you get to dance the victory dance soon.
Re: Distributor question 88 SWB 2.6 [Re: fasteddy] #826181 07/21/07 03:49 PM
Trail leader thank you for your advice it's been over 30 years since I pulled a motor. I am off to my garage to install the dizzy and the valve cover, I will report back how the engine start up went.
Re: Distributor question 88 SWB 2.6 [Re: fasteddy] #826182 09/11/07 05:56 PM
Boostcreepr Offline
For TDC cant you just pull #1 plug and rotate engine by hand and use somthing in the plug hole to feel with the piston is all the way up? Thats how i always did it.
Re: Distributor question 88 SWB 2.6 [Re: Boostcreepr] #826183 09/11/07 06:38 PM
hazy_daze Offline
Unless you feel pressure build up, you won't know if it's compression or exhaust stroke. That's why you stick a finger over the plug hole.
Re: Distributor question 88 SWB 2.6 [Re: hazy_daze] #826184 09/11/07 07:39 PM
Boostcreepr Offline
so are we lookin for the exhaust or compression? id say compression but you never know lol smile
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6269 MB (Peak: 0.7248 MB) Data Comp: Off Server Time: 2026-11-19 05:33:52 UTC
