drivetrain noise #826200 07/21/07 02:12 AM
F
ff11979 Offline OP
I have a 92 4wd pickup, just recently it has started making some noises on me. What it sounds like is when you let off the clutch youll hear a click or smack type sound. 3 out of 5 times when accelerating and running through the gears youll get a click click click loud and distinctive, however i cant pinpiont where its coming from. originally i thought clutch, but this morning just rolling down a small hill in neutral, i still heard it. anybody had the same problem, any ideas, any help would be appriciated. clutch is not slipping.
Re: drivetrain noise [Re: ff11979] #826201 07/21/07 04:07 AM
Snowtoy Offline
Since you were in neutral and still heard the noise, I would guess that it is either u-joints(more known for vibrations when going bad), or a wheel bearing, there isn't much else other than the engine turning when in neutral. I would find a slope long enough you could role down it with the engie of and see if you still hear the noise, this would eliminate the engine. I would also get one of your friends(or you could) to walk along side and see if they can hear where the noise is comming from.
You could also lift the one tire at a time and spin it and see if you hear anything.
Re: drivetrain noise [Re: Snowtoy] #826202 07/22/07 01:32 PM
F
ff11979 Offline OP
well found the problem, it was in fact a u-joint. didint really think about them at first. problem solved. thanks for the help.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5938 MB (Peak: 0.6474 MB) Data Comp: Off Server Time: 2026-06-09 22:00:26 UTC
