Starting #826227 07/21/07 11:08 PM
Superman Offline OP
My Tacoma runs fine once the engine starts. It is having several seconds of delay when I am trying to start it.
Any ideas? Is it the sparkplugs, battery or fuel pump? I don't think it is the fuel pump because if that is the case, it would still choke while driving.
Clark
Tacoma PreRunner Double Cab V6 Automatic
3.4-liter V6 TRD
Re: Starting [Re: Superman] #826228 07/22/07 07:35 AM
humanoid Offline
Do you mean if you fail to crank it the first time and try to crank it again and it won't start? I had the same problem. It was about time to change the spark plugs and the wires so I decided to do those and change the battery out as well. Doing those things solved my problem. When was the last time you changed your plugs out?
Re: Starting [Re: humanoid] #826229 07/22/07 09:51 PM
Superman Offline OP
I had the spark plugs changed April of 2006. The battery is still the manufacture battery which has been about 4.5 years now. I got a Diehard battery yesterday but have not put it in yet. The guy from Sears told me that it is the battery after he ran it through the test.
Clark
3.4-liter V6 TRD
Re: Starting [Re: Superman] #826230 07/24/07 02:09 AM
W
Whizkidder Offline
I'm having the same issue -- cranks for a long time before firing up. New plugs, wires, A/F sensor, air filter, battery; cleaned MAF, throttle body, all sensor & wiring harness connectors. Installed fuel pressure gauge -- FP within FSM specs for pressure and leakdown. Have used Seafoam both thru the PVC hose and in the fuel tank several times. Compression is w/in spec for all 6 cylinders
I think the only thing left is to remove the injectors and have them professionally cleaned.
Other than that, I've exhausted all my "good ideas." Frustrating.
Re: Starting [Re: humanoid] #826231 07/24/07 06:15 AM
Superman Offline OP
Turns out to be the battery. Put the new one in yesterday and everything is fine now.
Thank You
Clark
3.4-liter V6 TRD
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.014s) Memory: 0.6035 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-11-04 19:59:05 UTC
