Cherokee Lift #826234 07/22/07 12:00 AM
1
1tacomaInIt Offline OP
I'm thinking of getting a pair of factory Jeep Comanche leaf springs to put on my lifted Cherokee. I'm thinking it might give me 4"-6" of lift in the rear and maybe better flex back there. What do you all think?? Thanks!!
Peter
96' 2door 5spd Jeep Cherokee 6.5" Rusty's lift, 3/4" Coil Spacers, Ford 8.8" Rear, 4.10 Ratio, 35" BFG Mud Terrains, Locked Front, Limited Slip Rear, Roof rack, functional front and rear lights on rack
Re: Cherokee Lift [Re: 1tacomaInIt] #826235 07/22/07 12:12 AM
BobRowe Offline
How much is your Cherokee lifted now? Wha size tires are you running on it? What kind of wheerlin' do you do?
Re: Cherokee Lift [Re: BobRowe] #826236 07/22/07 12:20 AM
1
I currently have a Rusty's 3" on it with 31's. I'm looking to upgrade to 6" or 7". Mostly I do a little trail riding and some rock crawling.
Re: Cherokee Lift [Re: 1tacomaInIt] #826237 07/22/07 12:47 AM
fred1980 Offline
Are you looking to upgrade in tire size, why so much lift? 31's and 7" of lift doesn't function OR look good. You will raise you COG (center of gravity), which is not good especially if you do any off camber stuff and unless you go with front long arms your jeep will ride like cr*p on the road and will provided limited articulation offroad. With 7" of lift you'll be able to easily fit 35's or even 37-38's with a small bit of trimming. Once you step up to those tire sizes your current stock axles are deffinately not going to cut it....
Fred R.
Re: Cherokee Lift [Re: fred1980] #826238 07/22/07 01:00 AM
1
When I do the lift, I'm planning to go with 35's or 36's, a SYE, long arm in the front, 4.10's front and rear, and dana 44's if I can find a good deal on them. Otherwise I'm going to go with the Ford 8.8 limited slip in the rear and stick with the dana 30 with a locker in the front till I blow it out. Once I do all this, it won't be driven on the road much at all. So I'm really looking to get as much flex as I can out of the rear end of the jeep.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6022 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-06-22 12:31:34 UTC
