hub conversion
#826305
07/22/07 07:20 PM
Has anyone with the ADD system converted to manual hubs and locked up the actuater. Can this be eisily done. Any ifo would be appriciated.
Re: hub conversion
[Re: ff11979]
#826306
07/22/07 08:05 PM
88 V6 4Runner, 3.4 swap, SAS, front E locker, rear EZ locker, dual cases 2.28/4.7, 63" Chev rears, rears up front etc.
Re: hub conversion
[Re: ff11979]
#826307
07/22/07 09:19 PM
I took the side shaft from a non-ADD front and replaced the ADD stuff that was there. Just had to replace an oil seal (Toy Part# 90311-35032) in the diff before I bolted it back together. There is some kind of torx bit holding the ADD stuff on, Napa had the right size to get it out in stock.
Then just use locking hubs instead of the drive flanges and your set. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Fur clog in the sausage grinder
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5931 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-05-30 00:03:59 UTCValid HTML 5 and Valid CSS
