3.8L supercharged GM swap #826308 07/22/07 08:17 PM
Rhino58 Offline OP
Wondering if anyone has performed a 3.8L swap in a 2nd gen Isuzu Trooper. Wondering if the motor will bolt to the trans. Any info would be appreciated. Thanks! Gary
Re: 3.8L supercharged GM swap [Re: Rhino58] #826309 07/23/07 04:34 PM
houlster Offline
Isuzu Moderator
The 3.2/3.5 has a dual bellhousing bolt pattern on it. One of those is the 60 deg GM V6 pattern. If you have an automatic, then it has the 60 deg bell & will bolt up to a 3800 motor. You'll have to work out the converter/flexplate interface issues, if any.
Here's my 3800 SC motor swap.
--Dan
Re: 3.8L supercharged GM swap [Re: houlster] #826310 07/23/07 07:24 PM
I
IsuRS Offline
I was wondering if anyone happened to know is a 3.8 v6 will mount into a 2002 Rodeo sport In place of my 3.2 v6?? If not what other motors will?
Re: 3.8L supercharged GM swap [Re: IsuRS] #826311 07/23/07 08:15 PM
lttlbddy Offline
Your questions are answered in the post above yours IF you have an automatic.
Re: 3.8L supercharged GM swap [Re: lttlbddy] #826312 07/23/07 09:36 PM
I
IsuRS Offline
I found a 3800 that was set up on a FWD car does this matter?
Re: 3.8L supercharged GM swap [Re: IsuRS] #826313 07/23/07 10:26 PM
lttlbddy Offline
Houlster's motor was out of a 2002 Gran Prix, which I believe is a FWD. Read the link, then come back with questions. Doing your research one questions/answer at a time is not time effective.
Re: 3.8L supercharged GM swap [Re: houlster] #826314 07/24/07 06:36 PM
I
IsuRS Offline
If I'm not mistaken a 3800 v6 uses an entirely different ecu did you also tear that from the pontiac. Plz pardon my ignorance asked the first question beccause after the amigo became the rodeo sport some of the engine/tranmission fits changeand you see mine is an 02 RS. Has haulster finished the swap yet? How does it run?
Re: 3.8L supercharged GM swap [Re: IsuRS] #826315 07/24/07 08:20 PM
Jim_Paget Offline
WHEN you read Dan's write-up, you will see that he did a custom Mega-squirt ecu that he programmed.
While the tranny to engine mate up is important, it is a part of a much bigger picture.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 3.8L supercharged GM swap [Re: IsuRS] #826316 07/26/07 06:44 AM
randii Offline
Dan has finished his 3800SC swap, and has several years on it.
It runs strong, but it is a good bit slower off the roll than an Amigo with a 302. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Randii
Re: 3.8L supercharged GM swap [Re: randii] #826317 07/26/07 08:48 AM
mlclark Offline
Isuzu Moderator
I don't think Dan has flopped his yet... <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
PHP: 7.4.33 Page Time: 0.017s Queries: 16 (0.013s) Memory: 0.6370 MB (Peak: 0.7609 MB) Data Comp: Off Server Time: 2026-11-04 20:01:07 UTC
