SR rear axle - how strong is it? #826325 07/22/07 10:10 PM
7
777 Offline OP
V8 power hasn't been very friendly to all the axle parts. Close to 400hp instead of original 109hp is obviously too much for Mitsu 8" axles, so now itÆs time for a axle swap.
For front I will have Toyota Land Cruiser HJ-61 solid axle with factory locker and Longfield half-shafts. Theoretically should be as strong as 35spline Dana60, but half of the weight (compared to D60).
For rear one option would be Montero SR rear axle with 9.5ö diff and 1.32ö half-shafts.
Would it survive 400hp?
What tire size have you guys used with SR axle and has anyone broke one?
à or should I go directly Chevy 14bolt for rear? It would definitely be as strong as needed, but I donÆt like the extra weight, width, low clearance and 8 lug bolt patternà
Raider 6.0 V8 386hp, 397ft lb, 3?exhaust, Megasquirt ECU, EDIS ignition, Innovate LC-1 WB Lambda, NV4500, NP241 with JB conversions ?super short? SYE kit
Re: SR rear axle - how strong is it? [Re: 777] #826326 07/22/07 10:27 PM
hazy_daze Offline
Portals?
Re: SR rear axle - how strong is it? [Re: hazy_daze] #826327 07/22/07 10:48 PM
7
777 Offline OP
Portals?
I was thinking about Volvo C303/TGB11 portals. Here in Baltics and Scandinavia a lot of offroaders are using them. They have factory lockers and rated close to D60. The limitation is speed - max speed is about 60mph, even less for long time highway use.
Re: SR rear axle - how strong is it? [Re: 777] #826328 07/22/07 11:52 PM
hazy_daze Offline
I had never heard that before. Why would there be a speed limitation? Stability, geometry?
Re: SR rear axle - how strong is it? [Re: hazy_daze] #826329 07/23/07 01:52 AM
52degrees Offline
Sounds like heat they way he said slower for longer trips.
KG6VNX
Re: SR rear axle - how strong is it? [Re: 52degrees] #826330 07/23/07 04:26 AM
LandRaider Offline
I'd try an SR axle back there. It's not gonna cost NEAR as much compared to building a 60, or a 14 bolt for the rear.
Try getting a Locking axle from a montero sport like I have. SR size, but with leaf spring mounts. BOLT in for us leaf guys.
Re: SR rear axle - how strong is it? [Re: hazy_daze] #826331 07/23/07 07:54 AM
7
777 Offline OP
- hub gears and oil in there are getting extremey hot. One military mechanic told that a lot of the portal failures are caused by highway speeds.
Re: SR rear axle - how strong is it? [Re: 777] #826332 07/23/07 03:44 PM
sparkem Offline
Make sure you get the larger axle. There were the smaller 9in axles with lockers too.
Re: SR rear axle - how strong is it? [Re: sparkem] #826333 07/24/07 02:02 AM
i think a montero 9.5 is almost as strong as a dana 60 if not just as strong. it's a smaller axle but if you have gone over both axles the montero is built better. i had both in my garage for a while i did some comparing
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6306 MB (Peak: 0.7177 MB) Data Comp: Off Server Time: 2026-11-16 08:56:20 UTC
