Clutch master cylinder? Slave cylinder or something else? #826341 07/22/07 10:44 PM
Scotty_Gotti Offline OP
I replaced my clutch master cylinder yesterday because it was leaking bad. I got everything correctly assembled and bled the system with a one man bleeder. I am pretty certain that I cycled new fluid through the entire system. So here the problem, When the vehicle is started I cannot get it to go in to any gear at all. I have tried to bleed it repeatedly. There is a good range of movement down at the slave cylinder as well. Any ideas?
Re: Clutch master cylinder? Slave cylinder or something else? [Re: Scotty_Gotti] #826342 07/23/07 05:21 AM
kewlynx Offline
Did you actually check the pedal play/adjustment?
LINKY
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5868 MB (Peak: 0.6347 MB) Data Comp: Off Server Time: 2026-06-07 08:36:48 UTC
