Carb tag numbers #826431 07/23/07 04:36 AM
trickster Offline OP
I am looking at a used carb to rebuild for my truck. The current carb tag is 35290, the one I have found is 35291. Does anyone know what the difference between these two carbs is?
Re: Carb tag numbers [Re: trickster] #826432 07/23/07 05:06 AM
Scerb Offline
Probably nothing you could find if you looked for it. It'll swap over just fine.
-Scerb
Re: Carb tag numbers [Re: trickster] #826433 07/23/07 06:37 AM
kewlynx Offline
Take a look at the passenger's side of the carb and compare the hose ports. Some of the earlier ones have no additional port for the HAC. If you don't have one, it's not a driveability issue.
One of the nice indicators about a tag still even BEING on the carb is that it's an original; ie no rebuild.
I understand there is a slight difference between the carbs put on trucks vs. Celicas; Arbitrary Notion here should know; he used to be quite the rebuilder of these carbs while he was in college. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Carb tag numbers [Re: kewlynx] #826434 07/23/07 11:29 PM
ArbitraryNotion Offline
Thanks Margie smile
The numbers on the tag really aren't important. The only place I've ever seen them referenced on is the rebuild instructions form.
Great thing about these carbs is what is see is what you get. Just look and make sure the vac lines match up. Make sure the choke places and linkages look the same. There are problably 20 or so different models of carbs lumped into 2 main categorys. celica vs. truck For some reason the celica ones don't have a secondary linkage to the choke plate. They have a round hole in the choke plate. I was never able to get one of those carbs to run on a truck until I gave up and removed the choke plate. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Good luck and let us know how it goes.
Josh
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Carb tag numbers [Re: ArbitraryNotion] #826435 07/24/07 02:40 PM
Thanks for the info, I can see no physical difference between the two, guess I will start tearing it down after work. Then see how it swaps over.
Re: Carb tag numbers [Re: trickster] #826436 07/25/07 03:12 AM
kewlynx Offline
Use Scerb's website; it's in his sig here. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Carb tag numbers [Re: ArbitraryNotion] #826437 07/25/07 04:29 PM
fourwd1 Offline
The tag numbers are important if you're going to rebuild a carb.
A good parts store should ask for that number to get you the correct kit. If they don't ask, you're getting a generic kit, not one more specific to your carb.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Carb tag numbers [Re: fourwd1] #826438 07/25/07 06:42 PM
Scerb Offline
Honestly, I've never noticed a difference in the rebuild kits..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6261 MB (Peak: 0.7205 MB) Data Comp: Off Server Time: 2026-06-07 05:59:15 UTC
