can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds #826614 07/24/07 04:27 AM
cbrazor Offline OP
can the freeze plugs on a 92 yj 4.0 bereplaced with out removing the manifolds
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: cbrazor] #826615 07/24/07 04:29 AM
BigJim Offline
yes.
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: BigJim] #826616 07/24/07 04:32 AM
cbrazor Offline OP
ok how <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: cbrazor] #826617 07/24/07 05:32 AM
BigJim Offline
Find a way to punch the existing one into the block, it will not hurt anything in there. The put one of the expandable ones in place and tighten the bolt.
Ive never done one on that engine but have on many others. It is usually tight to get to but it should be doable.
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: BigJim] #826618 07/25/07 01:26 AM
Macka Offline
so by leaving the plug in the block it won't cause a restriction in flow???? I usually take a self tapping screw and put it through the plug and then pull the plug out with a piece of mechanics wire wrapped and tied around the ST screw
always working
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: Macka] #826619 07/25/07 01:45 AM
BigJim Offline
If they are all rusted and thinned out the screw will not work. Punching it into the coolant jacket has been done by just about everyone for many years. I've never heard of any ill effects.
When punching on one side or the other many times the thing will turn sideways in the hole and that enables pulling out with pliers.
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: BigJim] #826620 07/25/07 02:07 AM
playinmud Offline
X2
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds [Re: BigJim] #826621 07/25/07 03:39 AM
cbrazor Offline OP
thanks big jim <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6220 MB (Peak: 0.7163 MB) Data Comp: Off Server Time: 2026-10-21 22:06:30 UTC
