Stuff that comes with a marlin lift #826628 07/24/07 06:58 AM
L
Locked_Solid_Toy Offline OP
I was looking at the marlin crawler website and on his full lift kit one of the parts it comes with is a 3/8" spring pad, but only one.I was wondering if anyone knows why it comes with only one and if you are supposed to use it with his springs
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: Stuff that comes with a marlin lift [Re: Locked_Solid_Toy] #826629 07/24/07 11:43 AM
A
ashbyota Offline
Different spring perch heights on
the front axle. Passenger side is
real close to the pumkin. I thought
it was 1/4" difference from side to
side(heightwise anyway), that's
probably what that plate is for!!!
Re: Stuff that comes with a marlin lift [Re: ashbyota] #826630 07/24/07 01:08 PM
Scerb Offline
Ya, you weld that pad onto the driver's side perch to level things out.
-Scerb
Re: Stuff that comes with a marlin lift [Re: Scerb] #826631 07/24/07 05:25 PM
Red_Chili Offline
Toyota Section Staffer
The difference is approximately 3/8", hence the pad. Toyota made springs with different arches, the expense is not justified in most aftermarket springs.
-Bill
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6009 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-05-29 16:17:11 UTC
