Stuff that comes with a marlin lift
#826628
07/24/07 06:58 AM
I was looking at the marlin crawler website and on his full lift kit one of the parts it comes with is a 3/8" spring pad, but only one.I was wondering if anyone knows why it comes with only one and if you are supposed to use it with his springs
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: Stuff that comes with a marlin lift
[Re: Locked_Solid_Toy]
#826629
07/24/07 11:43 AM
Different spring perch heights on the front axle. Passenger side is real close to the pumkin. I thought it was 1/4" difference from side to side(heightwise anyway), that's probably what that plate is for!!!
[Re: ashbyota]
#826630
07/24/07 01:08 PM
Ya, you weld that pad onto the driver's side perch to level things out.
-Scerb
[Re: Scerb]
#826631
07/24/07 05:25 PM
Toyota Section Staffer
The difference is approximately 3/8", hence the pad. Toyota made springs with different arches, the expense is not justified in most aftermarket springs.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5998 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-11-03 12:29:20 UTCValid HTML 5 and Valid CSS
